Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Curved Curtain Wall
    December 9, 2010
    118
    04:36 PM
    Curved Curtain Wall
    I need to make a curved curtain wall. I know that the more curtain grids you place the smoother the "curve" will be, but it will still be faceted. How do you recommend going about creating a curved parametric panel?
    Kingdom of Denmark
    4,221
    01:36 AM
    Never done it, but I think that I´d create a custom curtain panel with a radius, and also make the horizontal "mullions" part of the panel (if they need to be curved too ?)
    BTW - Who on heavens earth can afford a curved curtain wall these days ?
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,489
    04:36 PM
    Quote Originally Posted by Munkholm View Post
    I see lots of curved glass in curtain walls, glass railings, etc but have yet to do one in Revit. I'm sure it's just around the corner so I'm paying attention here
    Moderator mark b's Avatar
    NSW Australia
    1,430
    09:36 AM
    Two ways you could do it.
    1. The cheat way, create a curved wall, make the wall thickness your glass thickness with a glass material. Then for mullions do them with horizontal and vertical wall sweeps, make your own profile. (see image). cheating I know but if you want it done quick and not worried to much about fine detail "and" you also get curved mullions ( which i don't think would happen in the real world ?)
    2. Or make a custom curved curtain panel set at you desired radius and swap out panels.
    Attached Files Attached Files
    4
    04:36 PM
    Curtain Wall panels are straight segments and you would need to figure out the radius to create a curved panel.
    I would create a mass in your project and us the Curtain System by Face tool, you can create the curtain grids and mullions the same way as you would for Curtain wall.
    JBZ
    JBZ is offline
    Senior Member JBZ's Avatar
    December 17, 2010
    Los Angeles
    670
    04:36 PM
    I haven't looked for this in a while since the cost is prohibitive for 99.999% of projects but there is a a curved curtain panel in the old Revit Libraries; at least in the 2009 libraries (I can't check 2011 since goBIM is trying to export a model right now) http://revit.autodesk.com/library/ar...tml/index.html
    Quote Originally Posted by t1shep View Post
    NSW Australia
    1,430
    09:36 AM
    Quote Originally Posted by JBZ View Post
    The second attachment in post #4 is a Curved Curtain Wall Panel family with adjustable radius just adjust radius to suit your requirements.
    December 9, 2010
    118
    04:36 PM
    http://www.screencast.com/t/iemnCX2Kkga
    oK. I'm trying to recreate what you did Mark. What am I doing wrong? Why can't I create a parametric arc that has a flexible radius and a flexible length?
    NSW Australia
    1,430
    09:36 AM
    Open the family I posted and have a look at it. If you delete the panel you will notice that under the panel is a 'curved reference line" which is being driven by the radius dimension and the panel is attached to the reference line.
    There is an eaiser way to make Curved curtain Wall in my other post.
    December 9, 2010
    118
    04:36 PM
    Curved Curtain Wall-1103011_admin-entry.jpgOK...I am sort of close to what I want...I was able to create the curved piece that I was after, but now I need it to do a little something different...See attached image.
    What I'm really trying to create are curved terracotta baguettes (sunshade.) I have different radius curves at different areas of the building. There are some instances where the there are two tangent curves together, and most of the time they transition into a straight segment. In addition, the lengths of the louvers vary, as does the material/color.
    As an in-place family, I can obviously create these. But they all become instances/ individual families and become a bear to edit and change the properties of.
    Any thoughts on an efficient, easy to manipulate and modify technique for doing this?
  1. Edit Top of Curved Wall
    Last Post: July 16th, 2015, 06:29 PM
  2. curved fin wall
    By t1shep in forum Architecture and General Revit Questions
    Last Post: March 1st, 2011, 08:24 PM
  3. Curved Curtain Wall Revisited
    By mark b in forum Architecture and General Revit Questions
    Last Post: February 23rd, 2011, 02:34 AM
Tags for this Thread
