Page 9 of 11 FirstFirst ... 567891011 LastLast
Results 81 to 90 of 106
Like Tree1Likes
Thread: Challenge: A parametric corner piece
  1. #81
    Kingdom of Denmark
    4,204
    11:07 PM
    Quote Originally Posted by mdradvies View Post
    ...Probably also not the most efficient way (although I also got stuck on the impossibility to convert integer or number values to model text). Bloated the family to 9,7mb.....
    Nothing is impossible, the impossible just takes a little longer... (and in this case, some longer formulas)
    Here you have it with 3D digitals, and st, nd, rd, etc... prefixed to the date
    Attached Files Attached Files
  2. #82
    Orlando, FL, USA
    3,029
    06:07 PM
    Ha! you actually did the formula with the 60 embedded if's for the minutes! argh... I wish the Factory would give us a simple function to convert reals or integers values to text, so that we don't have to do this.
    Well, your clock is awesome!
  3. #83
    Kingdom of Denmark
    4,204
    11:07 PM
    Yah, not really the way I wanted to solve it but it works, without exploding the file size
    Would be very nice if factory could build in a function to recognize characters vs. numbers and let us use number inputs for formulas, even if in a "text" field... I know nothing about programming in Revit, but something like this would be fairly easy in PHP (PCRE Patterns)
  4. #84
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    10:07 PM
    Quote Originally Posted by Munkholm View Post
    I'm not going to comment on that one... .
    But since when was the limitation on nested if's removed? I thought one could only go as far as 5 or 6.
    About the text to numbers: isn't it possible to use shared parameters in the family and assign a key schedule in the project?
  5. #85
    Kingdom of Denmark
    4,204
    11:07 PM
    Didn´t realize that we ever had a limitation on the if statements... but then again, I´ve never had to do sixty of them before...
    Just added a real digital display to the family
    Everyone -This family is just for the fun of it, but even if you don´t need a clock family, I´d strongly recommend checking it out if you´re interested in formulas and angular driven geometry
    Attached Thumbnails Attached Thumbnails Challenge: A parametric corner piece-clock.jpg
  6. #86
    78
    12:07 AM
    nice watch Klaus.
    unfortunally it doesn't run on my pc. it is just idle.
    wondering what specs i need, to make it run...
    -rpict
  7. #87
    Kingdom of Denmark
    4,204
    11:07 PM
    Batteries are not included... you´ll have to buy those separately
  8. #88
    Orlando, FL, USA
    3,029
    06:07 PM
    Munkholm´s clock is already my first nominee for the best post of the month. Amazing Revit skills! A clock with hours, minutes, and seconds, without using angular dimensions.
  9. #89
    Revit Maestro
    February 22, 2011
    6
    04:07 PM
    So now that I have "idiot-proofed" the clock so it is not possible for Bozo the Clown to make a mistake (Thirty Days Hath September...), what is the solution to ensure that Bozo can include the year yet enter February 29 is only for a leap year?
    Perhaps if Bozo makes a mistake and enters an impossible value, he should be prompted with a dialog box to make a different selection?!?
    Not, of course, that any of us reading this post have anything better to do with our time...
    [Note the smaller file size, corrected spelling in the parameter the modified hands to remove the "overlap" extrusion at the center circle. I think there is a name for this behavior - Obsessive Complusive Disorder? ]
    (Update: Simplified and shortened a few formulas and corrected a reference in the attachment. Sorry)
  10. #90
    Moderator mark b's Avatar
    NSW Australia
    1,429
    09:07 AM
    Are you guys serious ?? This is insane, are we building designers or clock makers ?? I think it is time to turn off your computers, go outside, and find a life !!
    This is "formula madness"
  1. Challenge: 7™ chair by Arne Jacobsen in native Revit Geometry
    By Munkholm in forum Architecture - Family Creation
    Last Post: March 26th, 2015, 04:30 PM
  2. Parametric Finish Materials
    By Munkholm in forum Tutorials, Tips & Tricks
    Last Post: August 18th, 2014, 02:47 PM
  3. Centre de gravité d'une pièce
    By Gwen44 in forum Forum Français
    Last Post: May 16th, 2011, 04:04 PM
  4. Challenge: a parametric scissors lift with multiple arms.
    By Alfredo Medina in forum Architecture - Family Creation
    Last Post: April 8th, 2011, 10:00 PM
  5. More Parametric Freakyness
    By mdradvies in forum Architecture - Family Creation
    Last Post: February 14th, 2011, 06:28 PM
Tags for this Thread
