Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By mdradvies
Thread: Generic model and structural framing beam and braces familes
    December 14, 2011
    57
    11:42 AM
    I created a Aluma beam family using the generic model family but when I insert the family into a project I cannot rotate the beams is there a way round this?
    My second problem is I created the same family using the beam and braces family, the beams come in standard lengths 1.22m, 1.83m etc however when I insert into a project I pick 2 points and this will derive the length of the beam is there anyway so that it will come into the project with the standard lengths?
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    06:42 AM
    Can you post the family? There could be several reasons why it won't rotate.
    As for the sizes, you need to create type parameters to control the length. Then, in the family, create your different types (lengths) and change the parameter for each one. If you have a ton of lengths, you may want to add a type catalog.
    December 14, 2011
    57
    11:42 AM
    dzatto here is the file
    Attached Files Attached Files
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:42 AM
    Well, basically it won't work cause you created the wrong template file. You made this as a Generic Model, which doesn't have the same freedom of manipulation as a Structural Beam (it will rotate, but only when using the "rotate" command)
    Alex Cunningham likes this.
    dzatto's Avatar
    December 9, 2010
    5,234
    06:42 AM
    Wow, thanks Martijn. I totally missed that he posted the file... that I asked for.
    Sorry for not responding Simon, but Martijn knows way more than I do anyway.
    March 29, 2012
    1
    07:42 AM
    How can you create a family with the structural beam template and make it a continuous beam bent where it slopes to a point and slopes back down. I made one in the generic model template and it works fine for what i need it for but i came across a problem when i needed it to have a moment connection on both ends. Do you know any way to resolve this? Thanks for any help you can offer.
    May 25, 2011
    192
    06:42 AM
    You possibly use this workflow, if I am understanding what you are looking for:
    1. Create a family that is half the beam, containing geometry from the end connection to the ridge.
    2. Create another family and nest the above family.
    3. In the parent family, copy/mirror the nest along the plane perp to the ridge and asign/link dimensional parameters for each half.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:42 AM
    Why not simply draw the Sweep sketch in elevation view? Then you can make it any shape you want. Only catch is: you'll need to rotate the profile in order to get it correct.
  1. structural framing tag
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 05:59 PM
  2. Structural beam system and floor
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: October 28th, 2011, 07:29 AM
  3. Replies: 1
    Last Post: May 23rd, 2011, 02:28 PM
