Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Like Tree2Likes
Thread: Formulas Type Parameters - Switches
  1. #21
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    10:07 PM
    If you really want a drop down, theres an easy way to do it:
    A Family type parameter. Nest in the three "options" as different families, unshared. Then use a family type parameter to switch between them, and whatever else theyre controlling.
    The only downside is in the project environment if you have more of those categories loaded....
    I looked at this when creating a custom Multi Category label (nesting labels in a multiline MC-label). But I don't think that it's possible to do this with annotation families. Or is the Titleblock a little different than other annotation families?
  2. #22
    Orlando, FL, USA
    3,029
    06:07 PM
    Quote Originally Posted by mdradvies View Post
    It is possible with annotation families, yes, and it is possible with titleblocks as well. Actually, a generic annotation familiy can be converted into a titleblock by just changing its category.
    The following paragraph and the attached illustration come from one of my old posts in Augi about this:
    "Another solution for this issue of swapping notes with different contents is this: One host annotation family with one family type parameter for generic annotations, and a set of generic annotation families nested into. For example, the file "Notes.rfa" hosts the following files: "Note 1.rfa", "Note 2.rfa", "Note 3.rfa", etc. These files shall have descriptive names, according to their content. By doing this, the family maker can create the notes independently, without any visual clutter. In addition, the host file needs very few parameters, maybe just one: the family type parameter. No need to use visibility parameters nor any formulas. On the other side, the end user just inserts "Notes" and then simply chooses, for example: "Note for Acme", "Note for Abc", etc."
    Attached Thumbnails Attached Thumbnails Formulas Type Parameters - Switches-swap-notes.jpg
    cganiere likes this.
  3. #23
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    10:07 PM
    But is this possible in a Multi Category tag? I'm trying to accomplish this with the attached tag. I recreated all the different labels in seperate families. But I can't nest these in the MC family to refer to.
    What I want to accomplish is similar to Alex' OP: I want to be able to swap the different labels.
    The current tag is composed of 11 lines of text labels:
    Mark (system value)
    Omschr0 to Omschr9 (which would add up to Description 1 to 9)
    Each Omschr-parameter is a type parameter, which holds a text description of the item tagged.
    Say I would want to tag a wall made of different layers.
    Layer 1: Exterior brickwork
    Layer 2: Air cavity
    Layer 3: Insulation
    Layer 4: Interior brick wall.
    Or a floor, roof, or any other component made out of different parts which I want to name in the tag.
    Using this tag I can fill in all the text labels to create one single tag.
    Why not use Material Keynotes? Well, because these layers often have multiple lines. For instance, a standard tag for this wall would contain the next lines:
    Omschr 0: Exterior brickwork, size axb
    Omschr 1: Color
    Omschr2: Mortar to be used
    Omschr3: Air cavity 30mm
    Omschr 4: 100mm insulation, manufacturer and type
    Omschr 5: fixation by....
    Omschr6: 100mm interior brickwork
    Omschr7: mortar to be used
    omschr8: finish (if not modelled seperately)
    This tag is normally used in a detail view. In a section view I would use the same tag, but only some lines (omschr 0,1,3,4,6,8). Because I can set the visibility for each line but I can't change the order in which the lines are displayed I have to use multiple tags and align them manually (tag1 for lines 0+1, tag2 for lines 3 and 4, etc)
    I posted an example of this workflow earlier in this thread
    If I could select the shared parameter which each label is referring to, I would be able to do this in 1 tag. But I never got this to work properly... Any ideas?
    Attached Files Attached Files
  4. #24
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    03:07 PM
    Exactly what I was looking for, and my brain is starting to figure out all the different areas I could use this system!!!. MORE REP POINTS!!!
  5. #25
    Orlando, FL, USA
    3,029
    06:07 PM
    ... Any ideas?
    Martijn,
    So far, I dont' see a way to do this. These are two roads which both go to a dead end:
    1) A multi-category tag can receive generic annotation families as nested, but generic annotation families don't accept shared parameters. Therefore, we can't have a multi-category tag that works with shared parameters and at the same time has labels that swap generic annotation families with a family type parameter.
    2) Generic model tag families can accept shared parameters but cannot be nested into the Multi-category tag. Therefore, again, we can't have a multi-category tag that works with shared parameters and at the same time has labels that swap model tag families with a family type parameter.
  6. #26
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    10:07 PM
    Martijn,
    Hi Alf,
    This is as far as I could take it myself... Too bad, but thanks for checking. Always a b***h when you find out you missed on checkbox in order for it to work. Still have the feeling I am missing out on something though. Can't put my finger on it. So I'll be working on it some more when I have the time.
    One question though: If I were to go for option 1, would the nested GA's still reflect on the item tagged? Or is the GA only referencing "itself" My current tag has the nice feature that the parameters "omschrijving 0-9" are dependent of the type of element. So, if I were to tag Wall type 1 and reuse this somewhere else in the project, it will have the same (consistent) text notes automatically.
    I think this isn't the case when using GA's is it?
  7. #27
    Orlando, FL, USA
    3,029
    06:07 PM
    ... Still have the feeling I am missing out on something though. Can't put my finger on it. ...
    Me too. Sometimes the pillow is the best consultant... maybe in a couple of days some solution might come up.
  8. #28
    9,905
    05:07 PM
    There are pros and cons to all of the systems, but that one with Shared Parameters has massive holes in it too. We use all of the different systems, for different levels of detail, which is a decent compromise.
    We use Material keynotes for Large Sections and Details, where we call out the individual elements.
    We use Item Keynotes or Tag-Type Comments/Description Tags by Element, at the Building Section / Elevation views where we want more general notes.
    You can circumvent the Keynotes with your own system, but Revit has enough holes that none of them will work perfectly. That system would scare the heck out of me, since the objects materials arent driving the note, the notes are all at the element level for something very detailed. If someone swaps out GYP for PLYWD, they also need to remember to go change the notes?
  9. #29
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    10:07 PM
    Yep, you would. But I have one rule: do NOT "change" materials without creating a new type. When creating a new type the tags automatically disappear. In the properties you can reselect them using a dropdown that automatically remembers previous entries and changed ones you retype.
    I do agree though: this one is not usefull for large firms with a lot of people using the notes.
  10. #30
    December 8, 2010
    Northern California
    3,567
    03:07 PM
    I have attached the family I created based on Alfredo's quoted post. Works like a charm. Thanks Again
  1. Fórmulas de Revit para el "uso diario"
    By Munkholm in forum Foro Español
    Last Post: December 14th, 2017, 06:44 PM
  2. Schedules & formulas
    By redmonki in forum Architecture and General Revit Questions
    Last Post: May 7th, 2014, 07:27 AM
  3. Moving switches in plan but not elevation?
    Last Post: April 29th, 2011, 08:32 PM
  4. Groups- Editing type parameters of a door
    By Elisa in forum Architecture and General Revit Questions
    Last Post: February 5th, 2011, 12:18 AM
Tags for this Thread
