Results 1 to 8 of 8
Thread: Filled Region or Masking for tags?
  1.    #1
    September 23, 2015
    190
    03:29 AM
    Like the title says guy. In the past my tags were transparent. This time I want to make them solid white. Any pro or cons I need to consider?
    Thank you
  2.    #2
    July 21, 2018
    79
    05:29 PM
    You can create the tag families with a visibility parameter for the region and use that in combination with linework to be able to switch between solid and transparent in a project setting. Ours are all solid by default, I think it reads a lot better that way, especially in plan views where there are floor hatches that can sometimes make reading tags difficult. And now that I think about it I'm not sure why/when people wanted them to be transparent... but I remember they were adamant about having the option, so it's there.
  3.    #3
    September 23, 2015
    190
    03:29 AM
    Do you use a filled regions or a masking region
  4.    #4
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    356
    07:29 PM
    Neither
    Just change the text from transparent to opaque - its in the text / label settings
  5.    #5
    July 21, 2018
    79
    05:29 PM
    OP i'm not entirely sure, I have a feeling we started favouring filled regions for one reason or another but I can't put my finger on it... Easier to change if one day people decide to colour the regions? Then again I might have it backwards. I imagine there's probably some of both knowing our library
    It's never impacted us though, have a feeling the only difference is something to do with how they're exported but we print and export a lot and never seemed to have any issues. So all in all this is a pretty useless post sorry, I'm afraid I can't really provide much more insight though, maybe someone else can steer us one way or the other.
  6.    #6
    September 23, 2015
    190
    03:29 AM
    thank you, no worries. Just trying to see it there would be any downstream issue with using a filled or mask. I am looking at some analytics software and I wonder if it would count the making regions inside the tags. I like the masking since it seems to cover everything.
  7.    #7
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    849
    05:29 PM
    Masking region in window and door tags works well. Opaque for text didnt make a clean edge inside border of tags. Can place tags over decking now with no lines inside tags from decking.
  8.    #8
    September 23, 2015
    190
    03:29 AM
    Thanks !
  1. Lines, Filled Region, and masks in tags changing insertion point
    By CRapai in forum MEP - Family Creation
    Last Post: July 17th, 2019, 07:02 PM
  2. Detail Item - Masking & Filled Region
    By MartinGT in forum Architecture and General Revit Questions
    Last Post: May 8th, 2019, 02:52 PM
  3. Masking and Filled Region Behind Model - Is it possible?
    By gpktm in forum Architecture and General Revit Questions
    Last Post: January 30th, 2016, 06:09 PM
  4. Masking to Filled Region Converstion - Is this possible?
    By revit_user in forum Architecture and General Revit Questions
    Last Post: May 13th, 2012, 07:26 AM
  5. Masking region refuses masking?
    By Shroudeye in forum Architecture - Family Creation
    Last Post: January 23rd, 2012, 06:20 PM
