Results 1 to 1 of 1
Thread: Variable Facade Panel Fail
  1.    #1
    Lurker
    November 28, 2018
    1
    06:39 AM
    I am a heavy Rhino/Grasshopper user transitioning to Revit/Dynamo.
    I am in the proccess of modeling a facade paneling system that will ultimately work with an attractor curve.
    The following was modeled in Rhino/GH; I want to model the same system in Revit.
    To achieve this, I've created 3 revit files:
    -A sweep profile as a conceptual mass
    -A curtain panel family that models each "bowtie".
    -A conceptual mass file with 2 surface with a checkerboard patterns, one of which is indented and globally rotated.
    Within the curtain panel family itself, all parameters run as expected.
    When implemented within the Conceptual Mass as an actual applied checkerboard pattern, only certain UV settings produce acceptable results; in other cases, the bowtie curtain panel family breaks in ways I don't understand where constraining dimension lines and predetermined symmetries are ignored.
    Variable Facade Panel Fail-revitquery892019-uvfail2-front.jpgVariable Facade Panel Fail-revitquery892019-uvfail-front.jpg
    Any help would be highly appreciated.
    Attached are all relevant rfa files.
    Thanks!
    Attached Files Attached Files
  1. Replies: 15
    Last Post: March 21st, 2017, 04:45 PM
  2. RTC: Plan to Fail
    By RTC in forum Blog Feeds
    Last Post: June 21st, 2016, 01:15 AM
  3. Revit Fail
    Last Post: December 18th, 2015, 03:37 PM
  4. Precast Panel Facade Documents using Parts
    By d.stairmand in forum Architecture and General Revit Questions
    Last Post: February 27th, 2015, 01:02 AM
  5. Do U Revit: DWF in the Cloud: #Fail
    By Do U Revit in forum Blog Feeds
    Last Post: March 23rd, 2012, 05:15 PM
Tags for this Thread
