Results 1 to 8 of 8
Thread: Family Rotation and Which Templates
  1.    #1
    October 30, 2013
    U.S. - Philadelphia, Pa
    57
    02:33 AM
    I hope this is a very simple problem. I drew an office chair starting with the seat from a side profile width (left right) and height (up down) then extruded (into the screen for say) for depth. When I try to load it into project it keeps wanting the put the side view normal to the floor. I want the chair to stand up not lay on its side. I have tried changing reference planes in family editor with no luck. I have tried numerous family templates (generic model, detail and profile). Any help would be greatly appreciated.
    Attached Files Attached Files
  2.    #2
    Mr. Revit OpEd
    2,952
    11:33 PM
    In the family editor the view names represent the real world orientation of the object (3D element categories). That means the plan view is plan. You created your chair lying on its side. You should have modelled it from a side view. You used the Casework category, a chair is normally assigned to Furniture...start with the furniture template. You can change the category still, Family Category and Parameters button on the Create ribbon.
  3.    #3
    Orlando, FL, USA
    3,140
    02:33 AM
    Hello, you said you "drew an office chair, ... then extruded... ", but what I see is a .dwg import, not something you "drew" or "extruded". Or do you mean you drew it and extruded it in AutoCAD? If you want to fix the rotation of this object, go to different views, and do one rotation at a time, until the front of the seat is facing the front of the view cube. But...
  4.    #4
    October 30, 2013
    57
    02:33 AM
    Quote Originally Posted by Steve_Stafford View Post
    Cannot believe I would have not of thought of that. Thank You very much! It probably is not good practice, but in reality you can draft in any template as long as you par attention to the elevation vs plan views. I almost always just use general model. Did casework just to see what's going on.
  5.    #5
    July 10, 2015
    Boise, Idaho
    692
    12:33 AM
    A lot of people make families in the general category then change it later.
  6.    #6
    Mr. Revit OpEd
    2,952
    11:33 PM
    Quote Originally Posted by DavidLarson View Post
    First question we have to ask is "What is this thing?" Start with a template for that thing's category. When a category template doesn't exist for it, we choose from one of the catch-all categories: Generic Model (cuttable) or Specialty Equipment (not-cuttable).
    Yes we can change a category later but if we assign things to sub-categories (or create them) we have to redo that work when we change it. I prefer to avoid that so I make the decision up front. If something forces me to change it later, outside my control...so be it.
  7.    #7
    October 30, 2013
    57
    02:33 AM
    How do you change it later? Copy and paste into a new family template?
  8.    #8
    Mr. Revit OpEd
    2,952
    11:33 PM
    While the family is open (Family Editor) > Create ribbon > Properties Panel > Family Category and Parameters button (yellow folder on the icon).
    Attached Thumbnails Attached Thumbnails Family Rotation and Which Templates-famcat.jpg
  1. Nested family and rotation
    By jbenoit44 in forum Architecture - Family Creation
    Last Post: September 12th, 2018, 09:55 PM
  2. Rotation of nested family
    By mona.miller in forum Architecture and General Revit Questions
    Last Post: August 28th, 2014, 03:15 AM
  3. Tag Family Rotation
    By darknes15 in forum Structure - Family Creation
    Last Post: June 19th, 2014, 03:30 AM
  4. Rotation Reference Family
    By gdoherty0102 in forum Architecture - Family Creation
    Last Post: February 27th, 2014, 12:15 PM
  5. Family rotation trouble
    By mmartin in forum Architecture - Family Creation
    Last Post: February 18th, 2014, 07:00 PM
