Results 1 to 2 of 2
Like Tree6Likes
  • 6 Post By ekkonap
Thread: Making a Yes-No Parameter Off by default
  1.    #1
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    356
    06:41 PM
    Discovered this nice trick yesterday
    When you normally make up a New Parameter using a Yes-No Tick Box, by default Revit Turns it "on".
    When you have a few family types that's OK - You just go & un-tick them in your Family
    If you have more than about 5 types...it becomes an pain
    I always wondered if there was a way to turn them to "off" by default?
    One of the chaps I work with (Big shout out to Tim DB) told me about this trick he uses:
    (We use "On/Off" on graphics alot in detail components. the following relates to this)
    1 Create the Element that you want to be shown as "Off" by default.
    2 Select the element.
    3 Un-tick its "Visible" Instance Parameter (This is the most important step).
    4 Then create and or apply the new parameter to the element.
    5 Go into the type properties & check that its "Off" by default.
    Attached Thumbnails Attached Thumbnails Making a Yes-No Parameter Off by default-1-2.png   Making a Yes-No Parameter Off by default-3.png   Making a Yes-No Parameter Off by default-4.png   Making a Yes-No Parameter Off by default-5.png
  2.    #2
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    587
    08:41 AM
    Or just use a formula '1=2', hit Apply and remove formula. Value is now set for every Type in the Family.
  1. Disable other yes/no parameter when checked without interrupting default not formula
    By corey0418 in forum Architecture and General Revit Questions
    Last Post: June 11th, 2019, 02:02 PM
  2. Editing the Default Parameter Value in a Family
    By Knapper77 in forum Architecture and General Revit Questions
    Last Post: September 11th, 2015, 04:50 PM
  3. Replies: 0
    Last Post: December 4th, 2013, 10:15 AM
  4. Can you schedule Default View Template parameter?
    By Craig Howie in forum Architecture and General Revit Questions
    Last Post: October 26th, 2012, 02:26 PM
  5. Setting default value for yes/no Shard parameter?
    By milos in forum Architecture and General Revit Questions
    Last Post: February 9th, 2012, 07:55 PM
