Results 1 to 2 of 2
Thread: curtain wall window panel offset
    Lurker
    July 17, 2019
    1
    11:38 AM
    Talking curtain wall window panel offset
    Hello,
    I've made a curtain wall window panel. Everything flexes, I've allowed for glazing thickness, depth and width of frame and materials for both.
    My question is creating the offset parameter for the panel once loaded into the curtain wall. (not a glazing offset). I can't edit and view the system family panels to see how they work their offset. But you can create a negative offset in them.
    In mine the closest I've come is creating the family on a ref plane that is offset from the centre plane, and the offset dim applied. That all works, but it naturally won't allow a negative offset, and the only workaround is to flip the window panel.
    Does anybody know how to create a offset parameter for a curtain panel (in this case a window) that allows a negative input, a la the system panels already in the template?
    November 4, 2012
    19
    06:38 AM
    Here is an article on how to create positive/negative parameters: don't think: Do Revit: +/- offset(s) for families
    Basically you will have a 'positive' dimension a 'negative' dimension and a parameter, and drive the dimensions with an IF formula.
  1. curtain wall window panel offset
    By biff in forum Architecture - Family Creation
    Last Post: April 12th, 2019, 08:13 PM
  2. Adaptive Curtain Wall Panel top/bottom offset issue
    By Zero34 in forum Architecture and General Revit Questions
    Last Post: February 8th, 2017, 11:56 PM
  3. Offset of curtain wall panel form basic wall
    By byk3bep in forum Architecture and General Revit Questions
    Last Post: January 20th, 2016, 11:17 AM
  4. Offset Curtain Wall Panel
    By DaveP in forum Tutorials, Tips & Tricks
    Last Post: June 8th, 2012, 08:15 PM
  5. Curtain Wall Panel with a nested Window! and u-value Calculation
    By Andrei.Ducu in forum Architecture - Family Creation
    Last Post: May 4th, 2012, 12:05 PM
