Results 1 to 1 of 1
Like Tree1Likes
  • 1 Post By Pingkingkonk
Thread: Multitag not centring on family inserted into project
    July 16, 2019
    Somerset, UK
    1
    05:38 AM
    Hi, yep I'm new to the forum....sorry...
    I have several families nested within a main family, all seems to work fine. I noticed once placed within a project the multi tag being used is offset to one side. Tag works fine. Initially it was on the left side and in the middle, not top and centred. I have gone through each nested family item to make sure the origin point is similar on each item and any item originally created horizontally but used vertically (in plan view) has been changed. This helps to get the tag to the top but still not centred. Any suggestions as I have several families to correct (made by others...). Thanks
    Actually I've fixed it!. It comes down to clean drawing practices. As I 'inherited' these families I had to go into each one - make sure the correct reference lines had the 'origin' point and that there were no rogue detail or hidden lines skulking on the outskirts that pulls the tag off centre. I hope any of this helps others.
    cganiere likes this.
  1. Families inserted into models
    By Dude__ in forum Tutorials, Tips & Tricks
    Last Post: July 24th, 2018, 07:48 AM
  2. Loaded family not being inserted
    By R8zbeh in forum Architecture and General Revit Questions
    Last Post: March 2nd, 2018, 06:35 AM
  3. If a CAD dwg is deleted, but still is loaded in the project, can it be re-inserted?
    By ryntau in forum Architecture and General Revit Questions
    Last Post: October 1st, 2015, 09:13 PM
  4. Custom family object pulls apart when inserted into project
    By Bpa in forum Structure - General Questions
    Last Post: October 25th, 2012, 12:56 AM
  5. DWG inserted into a Family
    By Alex Cunningham in forum Architecture - Family Creation
    Last Post: August 29th, 2011, 05:54 PM
