Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Like Tree8Likes
Thread: Family Origin Point
    June 27, 2019
    Minneapolis, MN
    14
    11:28 PM
    Family Origin Point
    Hello,
    Still new to Revit Family Creation, please bear with me on this question.
    So we have an older locker family that we recreated. We put the origins in the same spot. Back, center. When users go to replace the old family with the new one the whole family moves to suggest that the origin point is different. But they are not?
    Am I missing something? I would like to share with you the two families but my company will not let me. I also don't believe I can recreate the issue with a generic option. I will try, and will add to post later if I can. But wanted to get this out here first.
    Thank you,
    Michelle
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,021
    11:28 PM
    Reference Planes have a parameter named "Defines Origin"
    Only one horizontal and one vertical RP can be checked Yes. Where they intersect is where your Origin point is.
    June 27, 2019
    Minneapolis, MN
    14
    11:28 PM
    Yes we have that. They match in the old and new. But when replacing the old family with the new one it does not go origin to origin. The new family shifts location.
    Senior Member
    August 19, 2011
    New Hampshire
    505
    12:28 AM
    Check to see which reference planes/lines are pinned or not.
    10,362
    11:28 PM
    So, if the reference planes are marked as Defines Origin, but have been MOVED from their "invisible original location," really funky things can happen. Its one thing to switch which ref plane is the Defines origin... But if they have all moved, things can still shift.
    Only fix is to move the ref planes back to where they "used to be."
    GMcDowellJr likes this.
    June 27, 2019
    Minneapolis, MN
    14
    11:28 PM
    Quote Originally Posted by Andrew K View Post
    The Horizontal and Vertical Plane that is checked for Define Origin are both pinned.
    June 27, 2019
    Minneapolis, MN
    14
    11:28 PM
    It is a whole new family. Built from Scratch. not sure what you mean though by their invisible original location. The two families the origin matches on both. It's in the same spot. Didn't move it.
    10,362
    11:28 PM
    Quote Originally Posted by TrialandError View Post
    That you know of. It could be off in the Family Templates.
    Can you post the two families?
    Mr. Revit OpEd
    2,954
    09:28 PM
    If you have AutoCAD you can create an X (crosshair) at the WCS origin of the file. Import the DWG into the family, using origin to origin. It if lands at the intersection of your reference planes then the origin is in the same place. If not then you know the reference planes have been moved, at some point, away from it.
    June 27, 2019
    Minneapolis, MN
    14
    11:28 PM
    Quote Originally Posted by Steve_Stafford View Post
    This helped us solve the issue. Thank you so much! It seems the template we are using was changed up and the origin point was moved.
    But I thought there wasn't a "hidden" origin point in the file? I thought it was only where you defined the origin to origin?
    Twiceroadsfool likes this.
  1. Are the Origin and Project Base Point Always on Top of Each Other?
    By Helmet Fire in forum Architecture and General Revit Questions
    Last Post: March 17th, 2015, 06:42 PM
  2. Can't change family origin point, family loads into project as hidden lines
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 1st, 2013, 03:51 PM
  3. Replies: 0
    Last Post: July 23rd, 2012, 12:16 PM
  4. The Origin Point
    Last Post: January 23rd, 2012, 04:42 PM
  5. point cloud origin
    By pct in forum Architecture and General Revit Questions
    Last Post: December 16th, 2011, 08:31 PM
