Results 1 to 2 of 2
Thread: Length parameters for nested annotation families
    Junior Member Zuefeldt Design's Avatar
    October 29, 2017
    Denver, Colorado
    18
    02:16 PM
    Hi friends,
    I am working on an electrical family rig and am running into a roadblock on my symbol controls that I hope you might provide some insight on.
    I have nested a generic annotation family into my parent work-plane based electrical fixture family that serves as my electrical symbol. I would like to lock this nested family to a reference plane that can be offset off of the "host" reference line. This operation works inside the parent family but breaks inside the project environment. Note the outlet offset off the wall, but the outlet symbol remaining behind in the image below.
    I have built in an offset control within the generic annotation family that lets me independently move the symbol at paper space scale, but I want the symbol to follow the main reference plane as its origin point. It seems that I can not replicate the trick of grouping the generic annotation and invisible lines, then locking to a reference plane as discussed here.
    I have attached the family for reference if anybody wants to take a look. 2020, because the height off level tagging is awesome.
    Attached Files Attached Files
    October 29, 2017
    Denver, Colorado
    18
    02:16 PM
    With further testing I have realized this is an issue with the orientation of my electrical family with respect to elevation vs plan views. The offset works when I have the family positioned parallel with plan views and ceases working when perpendicular.
    Here's a question for the forum, are you building your outlet and switch families oriented to elevation or plan views inside the family editor?
  1. Replies: 10
    Last Post: October 25th, 2016, 09:33 AM
  2. Nested annotation families graphics and visibility overrides
    By Mat at YourCad in forum MEP - Family Creation
    Last Post: January 15th, 2015, 07:59 AM
  3. Linking parameters from different and non-nested families
    By jgu in forum Architecture and General Revit Questions
    Last Post: December 5th, 2012, 03:24 PM
  4. Shared Parameters in Annotation Families
    By Kevin McCurdy in forum Architecture - Family Creation
    Last Post: November 5th, 2012, 04:32 PM
  5. Revit OpEd: Connecting Parameters in Nested Families
    Last Post: March 8th, 2012, 02:15 AM
Tags for this Thread
