Results 1 to 3 of 3
Thread: Curved Railings with Panels
  1.    #1
    Member jsnyder's Avatar
    December 9, 2010
    AUGI Refugee
    347
    03:41 PM
    Forgive me if this has been addressed before, but I have not yet found a definitive answer. We have not done any curved railings in a while, so I was surprised when I discovered that the technique of using a tall thin profile for a top rail or non-continuous railing component does not appear to work for curved railings as it used to in version 2017. So how are people modeling curved railings with panels? Is everyone now using baluster panels (), or are we modeling in-place swept blends? Is there another way to do this?
  2.    #2
    December 20, 2010
    1,058
    06:41 PM
    You need to edit the path of the railing and extend the upper leg 1 tread length, and turn of any automatic infill settings. Curved Railings with Panels-staircurved.pngCurved Railings with Panels-stairround2.png
  3.    #3
    December 9, 2010
    AUGI Refugee
    347
    03:41 PM
    Thank you for the clues, Scott, but I am still missing something. The attached shows a rail modeled which only contains one non-continuous rail element. Clearly the geometry is still wrong. I get similar results when using only a top rail element for the panel. I have tried so many different options that I am not seeing something obvious.
    Attached Files Attached Files
  1. Fill a dubble curved mass face with panels
    By Mikeymore in forum Architecture - Family Creation
    Last Post: November 9th, 2018, 10:04 PM
  2. How can I model a curved an individual room module with curved edges
    By yumihah in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: September 27th, 2017, 10:38 PM
  3. Attach a curved wall to a sloped curved floor. HELP!!!!
    By peclat in forum Architecture and General Revit Questions
    Last Post: February 24th, 2017, 08:19 AM
  4. Problem with adding custom curtain wall panels to curved curtain wall.
    By aktaylorh in forum Architecture and General Revit Questions
    Last Post: November 20th, 2013, 06:16 PM
  5. Buildz: Repeat and Divide Prt I: curved panels
    By Buildz in forum Blog Feeds
    Last Post: May 7th, 2012, 05:15 AM
