Results 1 to 4 of 4
Thread: Line based void
    May 24, 2019
    Stockholm, Sweden
    6
    10:38 PM
    Question Line based void
    Hey all!
    I'm having some trouble creating a cutting family.
    What I'm trying to do is creating something that will cut floors without using the 'cut' function,
    and instead I'd like to use a family to do the job. So far so good.
    (This one was made by creating a void on a floor based plane, and cut inside the family editor)
    The main issue here is that I also need this to cut all the way to the edge of the floor, and I was thinking 'line based' might be the way to go? However, I'm stuck on this part and can't seem to get it right.
    (I've tried to load the previous family inside a line based generic model template)
    Are there any better ways to do this? Using In-place model/Void and cut is not an option here.
    Thanks!
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    356
    08:38 AM
    Some of the shapes need to get Cut into the Slab. I believe that Line Based is one of them. Faced based does it automatically.
    May 24, 2019
    Stockholm, Sweden
    6
    10:38 PM
    Thanks for answering!
    Any way to make the void continuous through out the whole side of the floor using this method without using a length parameter?
    January 19, 2012
    330
    03:38 PM
    I just adjust the Slab sketch to align with Exterior core of wall (exterior edge of mtl stud, for example). Then use a Slab Edge condition to get the Brick Ledge I want, as I can only assume from the image you provided.
  1. Floor based Void not cutting through
    By jean_francois_nant in forum Structure - Family Creation
    Last Post: February 23rd, 2018, 03:14 PM
  2. reveal vs line based GM vs face based GM
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: December 19th, 2017, 09:16 PM
  3. Line Based Family nested inside another line based family and arrayed
    By MadMatt in forum Architecture - Family Creation
    Last Post: January 6th, 2013, 05:29 PM
  4. Array a line based family inside another line based family
    Last Post: December 11th, 2012, 01:08 PM
  5. Face Based VS Wall Based VS Non-Host with Void Families
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: December 16th, 2011, 03:20 PM
Tags for this Thread
