Results 1 to 6 of 6
Like Tree8Likes
  • 2 Post By Twiceroadsfool
  • 2 Post By Profoxcg
  • 3 Post By DavidLarson
  • 1 Post By cellophane
Thread: Circles (voids or solids) in families - need ideas
  1.    #1
    September 23, 2015
    110
    06:37 PM
    Hello guys, I am building a family of a metal frame that has holes along the faces on the steel tubing. Think storage rack.
    The part I am struggling with is locating the circular voids on center and constraining them so that if the family flexes they can move etc.
    In other software this is very easily done since you can dimension to the center of a circle (place a constraint dimension). However you can't do this is Revit, at least not that I know of.
    The only way I manged to do this somewhat was to host each hole geometry to a reference line and then create constrains to the ref. line.
    Looking for a better way or alternate way. Autodesk the family editor needs to be more like fusion!
    Circles (voids or solids) in families - need ideas-revit-hole-constraints.jpg
  2.    #2
    10,178
    05:37 PM
    You can absolutely constrain the center of circles. Select the sketch line and turn on Center Marks. Then use the Align and lock.
    DavidLarson and Profoxcg like this.
  3.    #3
    September 23, 2015
    110
    06:37 PM
    OMG ! - dude. I am almost embarrassed to admit I never realized that check box was there.
    Thank you.
  4.    #4
    July 10, 2015
    Boise, Idaho
    661
    04:37 PM
    You're not the only one who never noticed it. Thanks for asking so more knowledge had a chance to be shared.
  5.    #5
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    06:37 PM
    If you really want to have some fun constraining curves, check out Paul's Renaissance Revit book: Renaissance Revit: Creating Classical Architecture with Modern Software - Paul F. Aubin I went so far as to get my copy spiral bound so I don't destroy the spine.
    Twiceroadsfool likes this.
  6.    #6
    10,178
    05:37 PM
    I had some good fun editing that book. And have some great screen shots from the Parkland days, while he and i were comparing notes. Its a TON of fun to read through.
  1. Cuttable Families - Revit Ideas Forum
    By cellophane in forum Out There
    Last Post: October 5th, 2017, 02:55 PM
  2. Families created from autocad solids
    By wgfletch in forum MEP - Family Creation
    Last Post: March 5th, 2015, 08:13 PM
  3. Revit OpEd: Voids Voids Voids
    Last Post: February 27th, 2013, 06:45 AM
  4. Modifying families to cut with voids
    By cellophane in forum Architecture - Family Creation
    Last Post: February 14th, 2013, 06:43 PM
  5. Problems related to Voids / Solids / Reference Planes in Massing
    By SkepticSon in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 21st, 2011, 02:11 PM
