Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By elton williams
  • 1 Post By cellophane
Thread: Shape Handles not snapping in wall-hosted families
    April 1, 2019
    4
    12:01 AM
    Is this a known Revit limitation? We have un-hosted cabinet families that have instance width parameters, and wall-hosted cabinets with the same thing. We can drag the shape handles of the un-hosted cabinets and they'll snap to nearby objects (walls, ref lines, etc) However, our wall-hosted cabinets don't "snap" to anything. We have to get close enough and then use the align tool, but this results in some lazier or more novice users just stretching the families "close enough" which causes errors down the road.
    I've just created a generic wall-hosted family and can replicate the issue.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,018
    11:01 PM
    Shape handles are strange animals. They play a funny game between parameters and Refernces.
    My guess would be your Reference Planes are different between the Base and Wall cabinets
    See here:
    https://knowledge.autodesk.com/suppo...1DF75-htm.html
    See especially steps 3 & 4
    Junior Member Steven_Campbell's Avatar
    December 21, 2010
    San Antonio, TX
    25
    11:01 PM
    Check the "is Reference" strength of the reference planes, if they are set to "Not a Reference" there will be no snapping or shape handles. If they are set to strong or any of the named settings (Front, Back, etc..) the snapping will be strong. The weak setting will be as expected weak snapping.
    Gold Coast
    2,631
    02:01 PM
    Quote Originally Posted by Steven_Campbell View Post
    Just to add...when using the align tool in the project, "strong" RP's will stretch an instance based dimension. "weak" RP's will shift the family over.
    duende123 likes this.
    April 1, 2019
    4
    12:01 AM
    EDIT: Just to be clear, our shape handles are showing up and stretching our families just fine. The issue is when we're dragging the handles of wall-hosted families, they don't snap to nearby elements (e.g. grid lines or adjacent walls). Non-wall-hosted elements' shape handles snap to nearby elements just fine.
    The reference planes are set to Left and Right. Everything is exactly the same between the two families except the host type.
    This behavior is the same with Doors (we have an adjustable/extendable sidelite that won't snap) and any other wall-hosted family we try to create.
    This behavior is also the same even with Autodesk's own wall-hosted families (e.g. windows)
    Can anyone upload a wall-hosted family where shape handle grips actually snap onto nearby elements? Thank you
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,186
    12:01 AM
    Weird. I'm seeing the same behavior, at least in quick testing. I guess I never noticed because I almost never use the shape handles
    https://www.screencast.com/t/EwA5vpS5rrKl
    steinah6 likes this.
    April 6, 2017
    9
    04:01 AM
  1. Shape Handles & Split Faces
    By evan.dodds in forum MEP - Family Creation
    Last Post: July 1st, 2015, 02:58 AM
  2. Unwanted Shape Handles
    By DaveP in forum Architecture - Family Creation
    Last Post: December 9th, 2014, 02:38 AM
  3. Beam shape handles
    By Henry in forum Structure - General Questions
    Last Post: February 24th, 2014, 06:34 PM
  4. Flexing Tag Family - Shape Handles
    By Alex Cunningham in forum Architecture - Family Creation
    Last Post: September 8th, 2011, 09:23 PM
  5. Shape handles
    By Randy_CaS in forum Architecture - Family Creation
    Last Post: September 2nd, 2011, 12:43 PM
Tags for this Thread
