Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Steve_Stafford
Thread: Stand Pipe symbol on every floor?
  1.    #1
    Junior Member deepblue02101996's Avatar
    November 22, 2017
    San Francisco
    19
    07:58 PM
    Community;
    i had a question regarding creation of a stand pipe family; i currently have an elevator family that when placed on the ground floor has the generic cabin repeat on every floor above it that i specify in a given height. i was hoping to make the same with a Stand pipe family. please find enclosed the two families that i am using and let me know if anyone has any advice in family creation to pull this off?
    let me know if anyone has any suggestions on improvement!
    thanks!
    Attached Files Attached Files
  2.    #2
    Mr. Revit OpEd
    2,861
    07:58 PM
    Add a invisible line that extends from the base to the "top". As long as this line intersects the cut plane of a level the family will show up in the view. If your family provides a parameter to set the overall height make sure your line is governed by this parameter so it crosses through ever floor's cut plane.
    deepblue02101996 likes this.
  3.    #3
    November 22, 2017
    San Francisco
    19
    07:58 PM
    thats it!!! awesome! thanks!
  1. Replies: 6
    Last Post: January 30th, 2019, 08:04 PM
  2. Pipe Cap Symbol
    By RobDraw in forum MEP - Family Creation
    Last Post: August 14th, 2017, 07:31 PM
  3. Flow Direction symbol in chilled water pipe line
    By santhorathi in forum MEP - General
    Last Post: February 16th, 2016, 09:32 PM
  4. Pipe tag indicates under or above floor
    By Menline in forum MEP - General
    Last Post: October 20th, 2014, 02:45 PM
  5. Pipe Fitting Symbol Problem
    By bhanna in forum MEP - General
    Last Post: September 20th, 2011, 08:51 PM
Tags for this Thread
