Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Dynamooo
Thread: Removing read-only parameters from a downloaded family
  1.    #1
    August 14, 2018
    8
    04:22 AM
    Hello,
    We have a family which is downloaded from the manufacturer. It has a list of greyed-out/read-only parameters. I would like to change 'Type Comments' because we use this for tagging. How can I made these parameters read-able?
    See below an images of the Type Properties from in the Project, and the parameter dialogue from the family editor.
    Thank you
    Attached Thumbnails Attached Thumbnails Removing read-only parameters from a downloaded family-capture.png   Removing read-only parameters from a downloaded family-capture.png
  2.    #2
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:22 PM
    Fold out the Identity Data Tab (in your bottom image) and you will see the Type Comment parameter there. It is greyed out in your project because there is a formula in that parameter. Remove the formula and you can fill in your own data.
    A good example of why I really don't like using manufacturers families.
  3.    #3
    August 14, 2018
    8
    04:22 AM
    Hi Robin,
    That's it! So simple, how did I miss it? Thank you.
    Robin Deurloo likes this.
  4.    #4
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:22 PM
    Quote Originally Posted by Dynamooo View Post
    Hi Robin,
    No problem !
  1. Removing family elements by parameters
    By mikey1073 in forum Architecture and General Revit Questions
    Last Post: November 27th, 2014, 03:08 PM
  2. Downloaded family not allowing parameters to be added
    By BenMiller in forum MEP - Family Creation
    Last Post: June 9th, 2014, 02:11 PM
  3. Strange flexing behaviour on downloaded window family
    By BLothian in forum Architecture - Family Creation
    Last Post: March 13th, 2014, 04:58 PM
  4. Can't edit downloaded family?
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 14th, 2013, 09:22 AM
  5. How to create views in a family you downloaded that only has the Ref. level view?
    Last Post: January 31st, 2013, 03:16 PM
