Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By scourdx
Thread: 2.5D Generic Model Family and View Range
    September 11, 2013
    69
    04:00 PM
    Hi All,
    I've been battling with this for hours and just can't figure it out...
    There's 2 generic model families - each one has a 2.5D family (detail items and symbolic lines) placed on the ref level plane.
    When loaded into a project, the families behave totally differently.
    One shows fine, whether the view range bottom limit is raised for not, the other one 'disappears' when the bottom limit is raised.
    The families seem to be built in exactly the same way, so I have no idea why they are behaving differently.
    If anyone fancies taking a look at the attached file to give this puzzle a go, it would be a great help!
    Many thanks in advance
    Attached Files Attached Files
    10,098
    10:00 AM
    I opened it to take a look, but immediately closed it after getting a headache.
    Respectfully, i cant figure out why you would work this way. It gimps half the intelligence of Revit. a bunch of Detail Items, in a Family, thats in a Family, thats in a Project.... Versus, just Modeled Items in a Group in a Project?
    September 11, 2013
    69
    04:00 PM
    Hi, I've stripped the families of further 3D elements because they aren't causing the problem, and for ip issues.
    The nesting is as follows:
    2D detail items nested into a generic model family
    Generic 2.5D family nested into a fully 3D version of elements.
    They wanted to be able to control the '2D' and 3D visibility of the family, and this made sense. There are also many various versions of this layout etc... so for cataloging this made sense also.
    I found a bodge for the one that isn't working by drawing an invisible line vertically in the 2.5D family. But still confused why the other family works without anything like this...
    Junior Member scourdx's Avatar
    July 4, 2013
    34
    08:00 AM
    Normally if you are using any 2d detail component into model family, I would add a parameter to elevation and draw an invisible model line. This way your model will behave the way you want it. If you don't do this, it won't behave the way you wanted. This is why you get some family shows up while another time it won't show correctly.
    Grumple likes this.
    10,098
    10:00 AM
    Quote Originally Posted by Grumple View Post
    Right. I wasnt misunderstanding what was done, technically. What im misunderstanding is: Why do any of that?
    Just model the 3d geometry, and show it. (and not in a family, yuck).
    September 11, 2013
    69
    04:00 PM
    Because this is a modular family that will be used on multiple projects.
    Personally, I find families far more manageable and useful than grouped elements (especially grouped 3D and 2D elements).
    September 11, 2013
    69
    04:00 PM
    Quote Originally Posted by scourdx View Post
    Thanks for this.
    That did seem to 'fix' this family, but I'm still not sure why one worked (without any 'vertical' elements) and the other didn't...
    July 4, 2013
    34
    08:00 AM
    I always want to know why it misbehave. Revit 2d component rely on the bring to front and back. Placing them in the model family lose that control. So you are at the mercy of the model object behavior. This is why adding the 3d invisible model line trick gives that control back.
  1. View range and window family
    By bangobeat in forum Architecture - Family Creation
    Last Post: October 20th, 2015, 04:51 AM
  2. Linked model view range/visibility issue
    By kmgates in forum Architecture and General Revit Questions
    Last Post: July 31st, 2014, 08:59 PM
  3. Generic line based family - Show only generic part in 3D-view
    By jkp4100 in forum Architecture and General Revit Questions
    Last Post: June 5th, 2014, 02:39 PM
  4. MEP Model Visible in RCP - View Range
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: January 17th, 2012, 11:27 PM
  5. controlling model component view range
    By redmonki in forum Architecture and General Revit Questions
    Last Post: August 23rd, 2011, 03:27 AM
