Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By Robin Deurloo
Thread: Broken Door Family
  1.    #1
    April 10, 2014
    South Australia
    2
    12:10 AM
    Broken Door Family
    Hi Everyone
    I've downloaded this door family from a local supplier. When trying to use and modify the family, the door size changes, but the frame doesn't. More specifically, when changing the door size to a 1020mm wide door, the frame opening doesn't change.
    I've tried playing around with the family, but i cant seem to pin point why this is happening.
    Any advice would be great. Thanks
  2.    #2
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:40 PM
    My best advise, build your own.
    There are a lot of things wrong with that family. I see geometry not linked to ref planes that control the size of it (the additional horizontal frame) and the door is not connected to anything as you have noticed by changing the width and I see no way of changing the width of the glass side panels for example. Also the thickness of the glass is linked to ref panels one 1 side but not on the other side, so if you need to change the glass thickness it will only change on one side.
    SO, I'm pretty sure you would have to go over everything to make it work, make sure there are ref planes to control the door width and location and connect the geometry to the right ref planes.
    Toni Pepperoni and jmk like this.
  3.    #3
    Coeur d Alene, ID
    4,698
    07:40 AM
    Ha ha... I wonder how old this family is? Did anyone notice the "Built By"??
  4.    #4
    Mr. Revit OpEd
    2,861
    07:40 AM
    Benn Design founder of RTC Events (now DBEI).
    The nested frame family is losing it's EQ constraint for Width in the upgrade. Edit that family and add it back in, load the family back into the parent and it should work again.
    Revit 2018+ has been much more fussy (and 2017 some too) about older families and constraints.
  1. No rooms in door schedule unless door family has Room Calculation Point
    By mgjp in forum Architecture and General Revit Questions
    Last Post: June 12th, 2017, 11:07 PM
  2. Family Editor changes 2012 - 2014. Constraint to nested family broken.
    By Duncan in forum Architecture - Family Creation
    Last Post: May 4th, 2017, 10:35 PM
  3. Taco Pump Family Broken?
    By RobDraw in forum MEP - Family Creation
    Last Post: August 15th, 2016, 01:34 PM
  4. Door Family: Can I have nested door panels with different driving parameters?
    By rpester in forum Architecture - Family Creation
    Last Post: October 28th, 2013, 05:04 PM
  5. Why is this Family broken?
    By Tim West in forum Architecture and General Revit Questions
    Last Post: November 8th, 2012, 06:56 PM
