Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By DavidLarson
Thread: Familien im Projekt drehen
    December 22, 2018
    4
    05:08 PM
    vielleicht kann mir jemand helfen?
    ich habe ein Familienbauteil (allgemeines Modell) ins Projekt (Grundriss, Ebene 0) geladen. Beim Versuch dieses Bauteil in der Ansicht Süd zu drehen kommt die Meldung: "Elemente können nicht in diese Position gedreht werden".
    Meine Frage: mache ich da etwas falsch oder geht das nicht?
    Vielen Dank im Voraus
    Pala
    July 10, 2015
    Boise, Idaho
    641
    10:08 AM
    Willkommen im Forum. Die meisten Leute hier sprechen Englisch. Ich werde jetzt Google Translate verwenden, da mein Deutsch begrenzt ist.Der Gastgeber für die Familie ist höchstwahrscheinlich das Problem. Können Sie die Familie hochladen oder uns sagen, um welche es sich handelt?
    Welcome to the forum. Most of the people here use English. I will use google translate for now since my German is limited.
    The host for the family is most likely the problem. Can you upload the family or tell us which one it is?
    snuffy likes this.
    June 12, 2014
    Fort Worth, Texas
    7
    11:08 AM
    In the Generic Models template, under "Family Category and Parameters", there is an "Always vertical" family parameter that is checked by default. This will only allow it be rotated in plan.
    If you are trying to rotate the family in an elevation or section view, unchecking this box and reloading the family should allow it.
    December 22, 2018
    4
    05:08 PM
    Question
    Quote Originally Posted by MTravis View Post
    Thank you for the Answer, I unchecked that box - but its still not rotateable?
    December 22, 2018
    4
    05:08 PM
    here the upload of the family
    January 17, 2019
    Brussels, Belgium
    9
    05:08 PM
    As far as I now this won't be possible even if you uncheck this box. This because a standard Generic Model needs a host (Level) to be placed on.
    Yes you can change after placement the host, but you can only select other levels, no workplanes nor gridlines.
    If you wan't to turn an generic model in a section you need to use a face-based family, place this on a face or workplane, and turn that face or workplane aftwerwards. The object will follow accordingly
    December 22, 2018
    4
    05:08 PM
    Quote Originally Posted by jmeu View Post
    Thank you for your answer
    Pala
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,486
    09:08 AM
    is this really true??
    December 21, 2010
    Phoenix, AZ
    2,556
    09:08 AM
    Quote Originally Posted by Dave Jones View Post
    Yes. Un-hosted really means level hosted. WPB allows both Reference Planes and Levels (provided they're parallel to each other). You can place on a workplane and then rotate the workplane if it's WPB but rotating freely in 3D space without rotating the host isn't something Revit does,
    Dave Jones's Avatar
    4,486
    09:08 AM
    Quote Originally Posted by GMcDowellJr View Post
    Interesting. I've never used hosted (face, floor, roof, etc) GMs. Always use WPB. I didn't realize that a generic GM would be automatically hosted by a level. Learn something new every day
  1. Sample Projekt 2019
    By andreasdraxl in forum Architecture and General Revit Questions
    Last Post: August 24th, 2018, 08:03 AM
