Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree3Likes
Thread: Creating Parameric hole (location)
    February 21, 2019
    Georgia
    11
    08:41 AM
    Hello everyone,
    I'm not sure if this is possible or how you might go about doing it. I'm trying to set a parametric location for a drain so that when you select a family type name it will move to that location based what you have selected. As of right now, the drain is constrained in the middle of pan. Here is a video to better illustrate my point.
    The video should work now.
    Thank you,
    https://youtu.be/krWJ1lvBZrM
    June 21, 2012
    Tours, France
    980
    12:41 AM
    your video is not available!
    February 21, 2019
    Georgia
    11
    08:41 AM
    Here is the link again. Sorry about that.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    05:41 PM
    You'll need to create a couple of Reference Planes, and dimension them.
    Then assign Type parameters to those dimensions.
    I assume that's a void that's creating the drain.
    Edit the Void Extrusion & select the circle that's the Sketch line.
    In the circle's properties, there's a check box for "Center Mark Visible".
    Check that and then you can Align and Lock the horizontal and verticals to your Reference Planes
    One more thing: You'll probably want to make those Reference Planes "Not a Reference". If you do, then in the project they won't show up when you use the Align tool
    February 21, 2019
    Georgia
    11
    08:41 AM
    Thank you for the reply. Will I have to create dimension lines for each location? The drain will have to be offset depending on the size of the pan. There is a center drain, off-set drain and corner drain.
    January 10, 2011
    St Paul, MN
    2,980
    05:41 PM
    That's why they should be a Type parameter.
    You add a Dimension, then assign a parameter to it.
    Then, for each size, you create a new Type, and set the correct location parameter
    February 21, 2019
    Georgia
    11
    08:41 AM
    You also mentioned "not a reference" how might I do this. I'm REALLY sorry about all the questions. I've only been working in Revit for about a week.
    February 21, 2019
    Georgia
    11
    08:41 AM
    Okay, I think I understand.
    February 21, 2019
    Georgia
    11
    08:41 AM
    How would you go about setting the location parameter? Thank you again in advance.
    February 21, 2019
    Georgia
    11
    08:41 AM
    I believe that I figured it out
  1. Replies: 0
    Last Post: June 7th, 2017, 07:15 AM
  2. Replies: 0
    Last Post: June 29th, 2016, 02:15 AM
  3. Hole in ribdeck E60 floor.
    By akaplan in forum Structure - General Questions
    Last Post: January 7th, 2016, 02:20 PM
  4. How to make this mullion above is parameric ?
    By ahmed_hassan in forum Architecture - Family Creation
    Last Post: January 25th, 2012, 11:12 AM
  5. Revit OpEd: Location, Location and Location
    Last Post: August 26th, 2011, 03:00 PM
