Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By DaveP
Thread: Family annotation visibility based on project Yes/No parameter
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    409
    12:54 PM
    Can I drive the visibility of elements (linework or nested annotations) in my Area tag based on the values of Shared Yes/No Instance parameters in my project file?
    I have an Area Plan with Area objects (but it could just as well be a Floor Plan with Room objects).
    I have an Area tag that reports the values of many shared parameters and Revit standard parameters. This includes text and Yes/No parameters. This all works fine - no problems.
    I would like to use those Yes/No parameters in the project to drive the visibility of nested annotations (or just plain simple linework) within my Area tag family. In other words: if the user checks on a certain Yes/No parameter for the Area object in the project, then display on this Annotation symbol in my Area tag.
    I don't think this can be done.
    I can nest in my Generic Annotation items (or I can draw simple linework) into my Area tag family.
    I can tie the visibility of these to a Type Yes/No parameter in the family file that is then visible in the project: but then this is dependent on the user in the project selecting the correct tag Type rather than relying on the Area parameter values - so that is not what I want.
    I can tie the visibility of these to an Instance Yes/No parameter in the family file, but then these are not then visible in the project.
    Attached is a v2018 Revit file showing the issue.
    Does anyone know how to achieve this please? Any help would be much appreciated.
    Thanking you in advance.
    Anthony
    Attached Files Attached Files
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,949
    09:54 PM
    I was all set to say "Sure you can!"
    Then I read closer & realized you're trying to tie the value that the Tag is reporting on to the visibility within the Tag.
    Sorry, but no.
    You can make different TYPEs of the Tag and have each Type display different information.
    But the information from the Area object itself can't affect the Tag.
    Best you could probably do is fire up Dynamo & have it select the Tag Type based on it's Area's parameters.
    anthonyB likes this.
    Member Darius's Avatar
    May 6, 2013
    482
    10:54 PM
    Also as a side note
    if you start adding a bunch of labels into a tag revit understands the total size of the tag (even the not visable stuff) and that gets your arrows to generate with gaps depending on what label in the tag you use
  1. Control family visibility with shared project parameter
    By Carchee in forum MEP - Family Creation
    Last Post: June 24th, 2016, 09:13 PM
  2. Visibility by scale based parameter
    By Hype in forum Architecture - Family Creation
    Last Post: June 21st, 2016, 02:28 PM
  3. Face based family annotation symbol
    By domsib in forum MEP - Family Creation
    Last Post: August 28th, 2013, 04:44 PM
  4. masking region contro11ed by instance-based visibility parameter...
    By lost again again in forum Architecture - Family Creation
    Last Post: November 12th, 2012, 11:22 PM
  5. Family Annotation Visibility Problems
    By KingEd5150 in forum Architecture - Family Creation
    Last Post: October 14th, 2011, 12:36 PM
