Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Like Tree14Likes
Thread: Rough opening for storefront and curtain wall
  1. #21
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,486
    12:25 AM
    Quote Originally Posted by danbush View Post
    So is this RO family what you use to cut the hole in the wall and then use a non-embedded CW in the opening?
    I don't make walls so have no need to cut a hole in them. The walls, with openings, that I use for my modeling are a part of the Architectural or Structural model that I link into my model.
  2. #22
    Coeur d Alene, ID
    4,744
    12:25 AM
    Quote Originally Posted by Hoangtin View Post
    Can we custom system mullion profile?
    Profile-Mullion.rfa
    Bit late...
  3. #23
    December 20, 2010
    1,053
    03:25 AM
    I think the "safest" thing an architect can do is model their design intent as I've been closely to how they want it, so Using a mullion on the perimeter with a shim space(approx.) built in is important, then we set the rough opening and know we won't be too far off. I've been pushing to stop showing ANY detail inside the profile and only Detail the location of the Sealant, Location of the weep at the bottom, and the distance to the connection in the head and sill from the exterior(too many times we forget about that and push the window out too far so there isn't enough concrete for the anchor. So in a perfect world I would model the mullion the size/ shape I want it with the glass in the right place and the right thickness, add the sealant detail component and the connection detail component and be done with it, point to the mullion with a tag that reads "Curtain Wall Sill Mullion" or CW Head Mullion, etc. then let the bidding and shops begin. We waste too much time showing manufacturer specific stuff only to have it changed or we get it wrong. Basically my rule is if I'm buying it as an assembly I don't have to detail whats inside that assembly only how that assembly interfaces with adjacent assemblies.
  1. Curtain Wall Storefront Wall - Custom mullions join issue
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: November 29th, 2018, 07:51 PM
  2. Editing storefront curtain wall
    By Ecotech Kid in forum Architecture and General Revit Questions
    Last Post: March 7th, 2016, 05:25 PM
  3. Curtain Wall - Storefront - Mullions resetting
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: August 5th, 2015, 04:46 PM
  4. Two-Three Windows - One Rough Opening
    By Craig.Donison in forum Architecture - Family Creation
    Last Post: November 15th, 2012, 03:10 PM
  5. Door & Window Rough Opening parameters
    By Gordon Price in forum Architecture - Family Creation
    Last Post: December 11th, 2011, 09:03 PM
Tags for this Thread
