Results 1 to 4 of 4
Thread: Blend with flat faces?
    September 11, 2013
    63
    03:45 PM
    Hi All,
    I seem to remember there being a trick to this, but can't find it anywhere.
    When you create a blend between 2 shapes (of the same number of points), how do you make the faces flat rather than 'curved' or 'twisted' ?
    I tied playing with the vertices direction tool, but that just seems to create all manner of odd shapes...
    Any info on this would be great!
    Thanks
    Senior Member
    August 19, 2011
    New Hampshire
    503
    10:45 AM
    You have to divide the profiles into a certain number of line segments for some shapes to blend well.
    September 11, 2013
    63
    03:45 PM
    This was using very simple polygons of 6 sides - blending a large one into a smaller version, and the faces were still twisted.
    The way I achieved the right shape eventually was to make an extrusion of 6 sides, then 'chisel' away the sides at an angle with voids.
    I thought there was a way of doing this with the blend tool, but maybe not.
    Orlando, FL, USA
    3,089
    10:45 AM
    Please provide some images. A blend solid of two hexagons, one smaller than the other, if the are aligned, should not produce twisted faces. But you might be doing something different. That's why for questions like this one is good to post some pictures.
  1. RTC: DTS New Year, New Faces, New Changes
    By RTC in forum Blog Feeds
    Last Post: January 10th, 2017, 01:15 AM
  2. Blend using Profiles
    By veuxx in forum Architecture - Family Creation
    Last Post: January 14th, 2014, 06:52 PM
  3. Please help with Swept blend
    By bhsdesigner in forum Architecture - Family Creation
    Last Post: January 17th, 2013, 10:52 PM
  4. Blend Too Thin
    Last Post: April 3rd, 2012, 07:00 PM
  5. Swept blend
    By assem in forum Architecture and General Revit Questions
    Last Post: September 23rd, 2011, 01:10 PM
