Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: room tag with occupancy info (2019)
    June 26, 2014
    87
    10:38 AM
    wondering if anyone has created a room tag that shows the occupancy info i.e. occupancy group, occupancy load factor(area per occupant), occupant load calculated?
    July 7, 2011
    Rotterdam, Holland
    1,235
    07:38 PM
    Nope, but I think that's just a few Shared Parameters to add to your tag and rooms
    10,200
    12:38 PM
    Unless you want to use Dynamo or an App (or a schedule where you manually translate them), you are better off with a tag that has Name and Number, and then a schedule (that you put on the sheet) with all the Occupancy Calcs. Reason being then that schedule can actually DO all the occupancy calcs for you. (Take the OLF, apply it to the SF, come up with OCC, round accordingly, generate plumbing fixture requirements based on that, and so on).
    As of 2017 or 2018, you can actually build all those calculations in to the TAG itself, but thats completely stupid because then its not in the model itself.
    tidalwave1 likes this.
    Member tidalwave1's Avatar
    December 9, 2010
    Las Vegas
    116
    10:38 AM
    not a room tag but an area tag. had to use dynamo and create a schedule.
    June 26, 2014
    87
    10:38 AM
    attached is a project that we have a schedule with what seems to be the appropriate parameters. if someone can tell me what i am missing.
    Attached Files Attached Files
    Orlando, FL, USA
    3,100
    01:38 PM
    Please be more specific. It´s not clear what you are asking. The project file does not contain any model elements yet and no custom room tag. I see some schedules showing some occupancy-related information.
  1. R&D BIM IoT Occupancy Comfort Sensor
    By m.p.diker in forum Third party Add-Ins, API and R&D
    Last Post: October 20th, 2014, 01:33 PM
  2. Occupancy Label Instance Text Parameter
    By DC1986 in forum Architecture - Family Creation
    Last Post: June 19th, 2014, 08:02 PM
  3. Model Text Using Room Info?
    By jhenry58 in forum Architecture - Family Creation
    Last Post: May 20th, 2014, 03:46 AM
  4. Sticky Notes: Calculate Occupancy Load
    By Sticky Notes in forum Blog Feeds
    Last Post: January 29th, 2012, 01:18 PM
  5. Revit OpEd: Occupancy Data Application
    Last Post: January 27th, 2012, 05:15 PM
