Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Munkholm
Thread: Family type visibility in 'edit family' mode
    January 16, 2019
    Reuver, Netherlands
    1
    11:43 PM
    Hello to all, I'm a fresh revit forum user.
    Despite browsing throught the forum here I didn't find an answer to my current revit-problem...
    Maybe you guys have an answer or tricks / ideas.
    The question is as following:
    I'm in the proces of making a family with several familytypes in it. The familytypes consists mostly of extrusions, voids etc.
    When I open the family, ALL of the elements used in ALL types are visible. Some of them are greyed-out, wich has to do with yes-no parameters being active or not. What I want is that only elements activated (with yes/no parameters) for a specific type are visible. I don't want inactive elements to be greyed out, but completely hidden from whatever familyview (floorplan, section, 3d etc>). Is this posible?
    When the family is loaded into a project all is functioning well. But because the family consists of somany types, it is very distracting and confusing when someone wants to edit the family...
    Kingdom of Denmark
    4,221
    12:43 AM
    Dave Jones likes this.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    12:43 AM
    You might also want to look into Nested Shared Families instead of building all your options/Types with visibility parameters.
    January 17, 2019
    Brussels, Belgium
    9
    11:43 PM
    Roel, as proposed by Munkholm, you can use the "Preview Visibility" Settings in the family editor for this.
    Once activated, only the visible geometry set by the parameters or LOD will be shown, all the rest will be hidden temporarily.
    To show you are in this mode a dark yellow border will appear around your work area.
    Kind regards
    Attached Thumbnails Attached Thumbnails Family type visibility in 'edit family' mode-preview-visibilty.png
  1. Using family type parameters in visibility parameter formula
    By jensslofstra in forum MEP - Family Creation
    Last Post: November 23rd, 2018, 03:49 PM
  2. Revit opens a new instance of family each time you edit the family from the project
    By Andrew P in forum Architecture and General Revit Questions
    Last Post: May 24th, 2016, 06:57 PM
  3. Replies: 0
    Last Post: March 27th, 2016, 07:18 AM
  4. Yes/No Visibility controlled by Family type dropdown
    By Benja_YC1 in forum Architecture - Family Creation
    Last Post: December 11th, 2015, 09:25 AM
  5. Revit 2014 - Double Click Family to Edit Type
    By willsud in forum Tutorials, Tips & Tricks
    Last Post: June 24th, 2015, 03:19 PM
