Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree1Likes
Thread: Using a formula to map mounting height to a label
    January 9, 2019
    10
    10:33 PM
    I have an outlet family. Typically the mounting height of this family is 18", but in the case that it is not, I want the MountingHeightLabel to appear AND display what that height is (so contractors can easily see which outlets are atypical). I can get the label to show/not show with a NOT formula, but I'm not sure if there is a way to have the value displayed. So if MountingHeight is <>18" show MountingHeightLabel and MountingHeight value
    Currently I have:
    MountingHeight as an instance length parameter
    MountingHeightLabel is an instance yes/no parameter (not sure this is the only way)
    I have the label itself as part of the nested outlet symbol family.
    January 19, 2012
    330
    09:33 PM
    Is this family Face Based, Wall Hosted, or Un-Hosted?
    If Wall or Un-Hosted, then you can easily create a Shared Parameter for you designated Height to then include in a Tag with or without the Unit Suffix (followed by text in the suffix properties of the parameter) instead of a label within a family that will most likely someone will want to adjust to clean up the positioning of it. Using a Tag is the best solution than an immovable Label (or you'll have to create tons more visual parameters for positioning) within the family.
    January 9, 2019
    10
    10:33 PM
    It is a face based family
    July 7, 2011
    Rotterdam, Holland
    1,277
    04:33 AM
    That is why I made a separate height parameter in some of my families, to be able to schedule or label it.
    The problem is that you can not schedule or label the offset parameter that is the 'normal' way to place something at a certain height.
    So what I need to be sure of is that I keep the offset of those families at 0 and that I adjust the height with my own parameter.
    You need to make all those parameters as a shared parameter and you can use that in the label and in the family. That way you should be able to link the text of the label to the value of the parameter.
    January 9, 2019
    10
    10:33 PM
    @Robin
    What type of parameter is the height parameter you create. That is currently what I have. So there is the Default Elevation parameter and then I added my MountingHeight parameter. Is that what you do?
    @cftrevizo I am also exploring the tag option
    January 9, 2019
    10
    10:33 PM
    Also, I can link the text of the label to the parameter no problem, but I want to be able to turn that label off and on depending on what the value of the height is. I only want the value to show if it is not standard mounting height.
    July 7, 2011
    Rotterdam, Holland
    1,277
    04:33 AM
    Yep, I made a Length parameter that I use for the MountingHeight (in your case). Be sure to make that a shared one, so you can use that to make a Generic Annotation with a label that displays that value. The standard Offset parameter should always stay at 0 or else the actual height would be wrong because the offset and your MountingHeight would be added together. I work by myself, so I know that I need to do that, when you have more people working with you you need to be sure they all understand that. I'm guessing a Dynamo scrips should be able to set all the offsets to 0 for you for example.
    I learned a trick from Aaron Maller to add the Generic Annotation to a Generic Model and add that Generic Model to your family. This way you can turn off the GM with the label with a filter if needed because you can not filter Generic Annotations.
    So you can build a formula that turns the visibility of that GM off when at a different value than the standard one.
    January 9, 2019
    10
    10:33 PM
    I really like the filter idea. It would work, except I am using the MountingHeight parameter for multiple families. The outlets, for example, have a different mounting height than the light switches. So I wouldn't be able to apply a filter in that case. I think I might have to go down the tag route, and only use it when the mounting height is atypical. I was hoping to avoid manual placing for this situation, but I just don't know that there is a workaround
    Thanks!
    July 7, 2011
    Rotterdam, Holland
    1,277
    04:33 AM
    No, you do not use the filter to set the data in the GA, you use the filter to turn off ALL the GA, in case you do not want to see them. You will be able to use a formula to turn off the GA when it is 'standard' height
    Make these:
    MountingHeight (length)
    DefaultHeight (length)
    TagVisible (Yes/No)
    Both TagVisible and MountingHeight would be Instance Parameters and the DefaultHeight can be a Type parameter you can set for each family (and also link to a global parameter if needed)
    In the last one place this formula Not(MountingHeight=DefaultHeight)
    This will turn the TagVisible parameter on or off depending on if both others are the same or not.
    January 9, 2019
    10
    10:33 PM
    Got it! Thanks!
    Robin Deurloo likes this.
  1. pier height anchor bolt height problem
    By Darius in forum Structure - Family Creation
    Last Post: November 20th, 2014, 08:26 PM
  2. How to Label the height of the receptacles?
    By Redtape in forum MEP - General
    Last Post: November 11th, 2014, 08:17 PM
  3. Family creation tip with Mounting Height
    By anthonyB in forum Architecture - Family Creation
    Last Post: September 5th, 2014, 06:56 AM
  4. Model height varies with project floor height
    By sabari2504 in forum Architecture and General Revit Questions
    Last Post: April 8th, 2014, 08:51 AM
  5. Walls - Full height or storey height is best?
    By john.warburton in forum Architecture and General Revit Questions
    Last Post: December 4th, 2012, 09:21 PM
