Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Andrew K
Thread: Type Catalog load error
    February 18, 2014
    10
    01:44 PM
    Hello all,
    I get this when i try and load a family type catalog.
    here is the txt file line.
    here is the parameter
    If i delete the family type parameter from the txt file it works.
    Attached Thumbnails Attached Thumbnails Type Catalog load error-error.png   Type Catalog load error-txt.png   Type Catalog load error-parameter.png
    Mr. Revit OpEd
    2,954
    01:44 PM
    It's controlling the selection of a nested family. There is either something wrong with that nested family choice (not applicable to this family) or related parameters that control it have values that apply to it that won't work. For example, a length parameter could be too short for it to be created or an array value setting the number of "rollers" might not be valid. Quite often one row of data in the type catalog has a zero or null value that was overlooked while it was being made. Then later testing didn't try that combination which would have revealed the issue earlier.
    February 18, 2014
    10
    01:44 PM
    There are no parameters for this nested family in the main family other than the one shown. I have this family in 9 locations. I turn them off by choosing a type that has nothing showing.
    I checked the txt file and can not find anything wrong.
    That specific type is the one currently in the main family for that type parameter. Unfortunately i can not post the models to a forum for peer review.
    FYI trying to import a type catalog into a family not a project.
    Attached Files Attached Files
    Mr. Revit OpEd
    2,954
    01:44 PM
    Then perhaps the nested family is constrained to something in the host differently than the other nested families. For example, if one nested family is designed to flex from the center outward but another nested family is meant to flex from the left to the right. If these two families are constrained (aligned/locked) in the host and can't flex the way they individually need to then Revit will complain.
    Senior Member
    August 19, 2011
    New Hampshire
    505
    04:44 PM
    I've found when importing a type catalog to a family inside of the family editor, it cannot handle Family Type parameters.
    Steve_Stafford likes this.
    Mr. Revit OpEd
    2,954
    01:44 PM
    Quote Originally Posted by Andrew K
    ...it cannot handle Family Type parameters...
    Well that would account for it...
  1. How do you load a type catalog with a family?
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: July 17th, 2017, 06:30 PM
  2. Replies: 0
    Last Post: May 10th, 2015, 05:16 PM
  3. Load Family with Type Catalog
    By boilermakercb in forum Third party Add-Ins, API and R&D
    Last Post: June 2nd, 2014, 05:45 PM
  4. Type catalog error
    By Andres Franco in forum Architecture - Family Creation
    Last Post: February 13th, 2014, 01:38 PM
  5. Load from type catalog of a different family?
    By cbaze in forum Architecture and General Revit Questions
    Last Post: February 10th, 2012, 03:47 AM
