Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Like Tree13Likes
Thread: Flipping doors
  1. #11
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    307
    04:32 AM
    Quote Originally Posted by mjajansen View Post
    We can flip doors in Revit but i don't want to do that in the projects we do.
    We got left swing doors and right swing doors and thats it for interior.
    So, just to be Captain Obvious here; you do know that it's perfectly possible to mirror any door, and spoil all your pretty systems?
    It takes really strict discipline to avoid this being done by mistake ( or intentionally). I hope you have your workers under control :-)
  2. #12
    9,775
    09:32 PM
    Quote Originally Posted by tuekappel View Post
    Yep Yep. Unfortunately, in Revit, the only way to properly handle Handing, is as an Instance Report, through the API or Dynamo. Things can be Mirrored, Flipped, and Mirrored-and-Flipped.
    But, reporting handing was one of the first cool uses that made me want to understand Dynamo, back in the day... When Havard V made a cool video about Door Handing, and used The Phoenix Alive for the background music. LMAO.
    tuekappel and ScubaMan like this.
  3. #13
    Member mjajansen's Avatar
    December 26, 2011
    The Netherlands
    161
    04:32 AM
    I know it can be mirrored but at least it can't be with the spacebar or the arrows on the screen, which eliminates 90% of the problems.
  4. #14
    December 21, 2010
    Phoenix, AZ
    2,474
    08:32 PM
    So now you can say that you can all but guarantee that 90% of the work is correct... and no way of knowing which 10% is incorrect.
  5. #15
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    333
    04:32 PM
    Easy to spot the 10% that's wrong...It's the bits that have been done by someone else!
  6.    #16
    December 26, 2011
    The Netherlands
    161
    04:32 AM
    I have been looking again at this and it's still not how i want it, the 10% needs to be eliminated.
    I want people to flip/mirror/copy/rotate what they want and still get the correct pieces in a schedule.
    Does any of you have an idea on how to do this the correct way?
  7.    #17
    9,775
    09:32 PM
    You can REPORT it correctly AFTER the fact, through Dynamo or the API. It cannot be done without an external app or program, because you cant stop folks from mirroring like you could in AutoCAD.
  8.    #18
    December 26, 2011
    The Netherlands
    161
    04:32 AM
    I know, and i Googled for a dynamoscript and found something from archi-lab, but don't know if that's the right one to use.
    If anybody has a better idea or link to a dynamoscript (dynamoplayer to make it even easier ) or a link to a forum where it is explained, that would be very nice. Got to learn Dynamo someday, better start sooner than later.
  9.    #19
    9,775
    09:32 PM
    Im curious what terms you googled that didnt find a result? I just ran a quick google search, and found three posts on the first page of search results, that had actual graphs in them.
  10.    #20
    December 26, 2011
    The Netherlands
    161
    04:32 AM
    I have found these 2 links and they seem to work nice, but maybe there is a better/easier way to do it.
    https://vasshaug.net/2014/09/01/door...tion-in-revit/
    door set handing | archi-lab
  1. Structure missing when flipping section
    By CRapai in forum Architecture and General Revit Questions
    Last Post: January 16th, 2018, 12:58 PM
  2. Building Coder: Flipping a Section View and Forge Webinar 3
    Last Post: September 26th, 2016, 12:45 PM
  3. Link model disappear when flipping the side of a section view
    By Bimerworld in forum Architecture and General Revit Questions
    Last Post: August 31st, 2014, 09:31 PM
  4. Flipping support wall
    By Barrie in forum Structure - General Questions
    Last Post: March 11th, 2014, 10:03 AM
  5. Joined walls and Doors- doors with different expected width
    By Hugo Tavares in forum Architecture and General Revit Questions
    Last Post: May 8th, 2012, 05:39 PM
