Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By cellophane
Thread: Window Brickmould: Nested Face Based Families Not Cutting
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    11:00 AM
    I'm having an issue getting my brickmould to cut properly once I'm in a project and I can't figure out why. I pulled up my old windows (c. 2017) and everything cuts correctly, but the new windows don't... The brickmould family is built the same way (I'm pretty sure it was a save-as & cleanup) so I can't figure out why one cuts appropriately and the other doesn't. Any insights into why one works as expected and the other doesn't would be appreciated.
    Project file with a dumbed down version of the new window and one of the old windows attached.
    Attached Thumbnails Attached Thumbnails Window Brickmould: Nested Face Based Families Not Cutting-windowbrickmould.png
    Attached Files Attached Files
    August 9, 2011
    Louisville, KY
    6,104
    11:00 AM
    le bump.
    10characters
    August 9, 2011
    Louisville, KY
    6,104
    11:00 AM
    And I poked blindly at it long enough and got things working
    Extended the void so it cut the face, then pulled it back to be flush with the face. For some reason this doesn't give an error about not cutting, which results in everything working in the project environment.
    elton williams likes this.
  1. Void cutting nested families
    By dan_p87 in forum Architecture - Family Creation
    Last Post: October 18th, 2013, 04:10 PM
  2. Louver - Better to be a Window Family or a Face Based Generic Model??
    By Joshua Kohl in forum Architecture - Family Creation
    Last Post: September 19th, 2012, 02:04 PM
  3. Proxy face in Face Based families - delete it?
    By Gordon Price in forum Architecture - Family Creation
    Last Post: February 5th, 2012, 08:07 PM
  4. Face Based VS Wall Based VS Non-Host with Void Families
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: December 16th, 2011, 04:20 PM
  5. Face-based family cutting two walls at a corner
    By hroark in forum Architecture - Family Creation
    Last Post: December 28th, 2010, 03:43 PM
