Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By Dave Jones
  • 1 Post By cellophane
Thread: Shared Parameter File Rework
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    04:53 AM
    I'm rebuilding some families and in the process am trying to fix some SP issues - duplicate parameters, crappy naming, etc. Ideally I'd like to just get rid of the old parameters and create new ones but I realize that might not be the most optimal solution. As a semi-workaround I've created new parameter groups and new revised parameters, but it is a giant suck to try and replace them in families (even with CTC Suite.) Is this the best workflow or am I totally overthinking something here? Would creating a separate SP file for creation that gets merged later into the main SP file be a little easier? I'm not keen on the current naming system for my new parameters but I need someway to differentiate between old parameters and new parameters, which would be eliminated by using a new file, then erasing all the old parameters & merging the two files (I think.)
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,489
    01:53 AM
    it seems to me that it's time to go on that distillery tour
    cellophane likes this.
    August 9, 2011
    Louisville, KY
    6,140
    04:53 AM
    Quote Originally Posted by Dave Jones View Post
    I did one last weekend... I have to get work done every once in a while
    Dave Jones likes this.
  1. Replies: 0
    Last Post: February 10th, 2016, 07:15 AM
  2. Replies: 0
    Last Post: January 13th, 2016, 02:45 AM
  3. Replies: 0
    Last Post: January 12th, 2016, 05:45 AM
  4. Replies: 0
    Last Post: January 11th, 2016, 04:45 AM
  5. Replies: 0
    Last Post: August 11th, 2011, 07:20 PM
