Results 1 to 4 of 4
Like Tree4Likes
  • 3 Post By Robin Deurloo
  • 1 Post By GMcDowellJr
Thread: <Yes/No> control <Text> or <Number>
    Junior Member Vester85's Avatar
    January 3, 2017
    12
    10:49 AM
    Hi everyone.
    I can seem to figure this one out...
    Im looking for a formula to control Text-Parameter or Number-parameter by a Yes/No-Parameter
    My best way to describe it, is by a failed if statement
    In a text-parameter formula;
    =IF( [Yes/No] = 1<2, "Text 1", "Text 2" )
    < IF [Yes/No] = True, Then "Text 1", Else "Text 2" >
    In a Number-parameter formula;
    =IF( [Yes/No] = 1>2, "0", "1" )
    < IF [Yes/No] = False, Then "0", Else "1" >
    How can i make this work?
    Sendt fra min SM-G935F med Tapatalk
    July 7, 2011
    Rotterdam, Holland
    1,230
    11:49 AM
    For text
    Make a yes/no parameter (in my example it is test01)
    Make a text parameter (in my example it is test02)
    in test02 place this formula if(test01, "yes", "no")
    For number
    Make a number parameter (in my example it is test02)
    in test02 place this formula if(test01, 0, 1)
    No need for fancy IF parameters when working with yes/no
    January 3, 2017
    12
    10:49 AM
    Thank you for your answer.. I'll try that..
    Thats very simple indeed...
    December 21, 2010
    Phoenix, AZ
    2,600
    02:49 AM
    Quote Originally Posted by Vester85 View Post
    To clarify - putting quotes around numbers that need to be numbers turns them into strings (i.e. text).
    Robin Deurloo likes this.
  1. Control model text position using parameters
    By allan120791 in forum Architecture - Family Creation
    Last Post: April 4th, 2017, 10:29 PM
  2. Replies: 20
    Last Post: November 23rd, 2015, 08:31 AM
  3. Room Number / Door Number
    Last Post: July 16th, 2014, 11:19 AM
  4. Room Number & Space Number
    By LKeyser in forum MEP - General
    Last Post: July 3rd, 2012, 02:48 PM
  5. Text notes visibility control
    By redmonki in forum Architecture and General Revit Questions
    Last Post: March 21st, 2012, 04:23 PM
