Results 1 to 3 of 3
Thread: Create extrusion with sinuous-line shaped surface
    m k
    m k is offline
    May 29, 2018
    2
    10:10 AM
    Angry Create extrusion with sinuous-line shaped surface
    Dear all,
    I am trying to create a Revit extrusion with a sinuous-line shaped surface.
    - extrusion should be variable in size (length, width, height)
    - one side shoud have ripples "sinuous-line shaped surface"
    - size of ripples should stay constant only the number of ripples should change when flexing
    I tried to work with
    - line based family
    - profile family
    - sweep with one of the above -> did not work
    - extrusion of one of the above -> did not work
    None lead to the desired result.
    -- Any hints for me --
    cheers
    Michael
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    11:10 AM
    Create a family of 1 desired ripple, not a profile, just a generic model family with 1 off your repeating unit. Make that variable in width, length, height.
    Nest that into another Family (could be line-based if desired, I wouldn't do it personally), make an array of your unit there. ink your parameters to the host family.
    Have a slightly modified version of your ripple family with a void on one end that cuts away part of the ripple length, use that one to fill out any length that is left after all the full ripples are placed.
    m k
    m k is offline
    May 29, 2018
    2
    10:10 AM
    Thanks Bjorn_K,
    this does the job !!!
    I needed some tries with the nesting (Revit seems sometimes erratic in that).
    But finally it works.
    Thanks Again
    Michael
  1. Possible to create a poly-carbonate luminaire family shaped like a cloud?
    By idame in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 11th, 2019, 02:03 AM
  2. How do I create a Y shaped column?
    By dylanrevitq in forum Architecture and General Revit Questions
    Last Post: January 29th, 2018, 07:35 PM
  3. How to create a sub-region on a topo with no surface?
    By Reneedet in forum Architecture and General Revit Questions
    Last Post: June 20th, 2017, 05:22 PM
  4. Lock plan based extrusion to reference line in section
    By Glenn Arne in forum Architecture - Family Creation
    Last Post: July 8th, 2016, 03:44 PM
  5. Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)
    By Glenn Arne in forum Architecture and General Revit Questions
    Last Post: January 27th, 2016, 10:58 PM
