Results 1 to 7 of 7
Thread: adjust titleblock revision schedule row height
    July 20, 2011
    850
    10:45 AM
    i thought it's automatic but seems not the case, forgot how to do it, can anyone point me to right direction? thanks
    Attached Thumbnails Attached Thumbnails adjust titleblock revision schedule row height-capture.png
    January 19, 2012
    327
    12:45 PM
    Select the Schedule in the PB, then in the Properties Palette go to Appearance Tab, The Height setting....swap that.
    July 7, 2011
    Rotterdam, Holland
    1,235
    07:45 PM
    I think it is controlled by the text height in the table in your titleblock family.
    July 20, 2011
    850
    10:45 AM
    that's what i thought, as long as text height changed, all rows will change automatically (not just 1st row w/ text), in fact, it's the case when i created titleblocks for A0 and A1, somehow it's not working for A2, etc.
    edit: OK, figured out, it's the body text need to change height, thanks all
    July 7, 2011
    Rotterdam, Holland
    1,235
    07:45 PM
    So maybe the option cfrevizo mentions is set the wrong way for that titleblock?
    And aren't you just copying the A1 and changing dimensions for the A2 titleblock?
    Or even have 1 titleblock family for all the sizes?
    July 20, 2011
    850
    10:45 AM
    thanks Robin and cfrevizo, i need to change body text height instead of just title/header.
    well, we create separate TBs for metric A0 ~ A4, and imperial A ~ E, sounds crazy or better way? is 1 TB for all sizes really work?
    July 7, 2011
    Rotterdam, Holland
    1,235
    07:45 PM
    yeah the body text, that sounds logical .
    I have one for A2, A1 and A0 but also for extended sizes (large formats) and 1 for A3 and A4 (small formats) because those look very different for me.
    So just 2 families with a few types. I think it is easier to manage having them as 1 family instead of having one for each size.
  1. Revit MEP copy revision schedule to different titleblock
    By baggins79 in forum Architecture and General Revit Questions
    Last Post: May 18th, 2018, 07:54 AM
  2. Adjust Tag Leader Height Origin
    By SamHenderson27 in forum Tutorials, Tips & Tricks
    Last Post: December 1st, 2015, 06:40 PM
  3. Titleblock revision
    By alijack in forum Architecture and General Revit Questions
    Last Post: March 31st, 2014, 12:58 PM
  4. revision clouds in legend views do not generate revision schedule entries
    By hclbaumbach in forum Architecture and General Revit Questions
    Last Post: July 1st, 2013, 10:39 PM
  5. Tekeningenlijst/schedule van sheets met revision schedule
    By rijber in forum Nederlands forum
    Last Post: February 2nd, 2013, 01:50 PM
