Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Alfredo Medina
Thread: Visibility Settings in Schedules?
    February 23, 2015
    2
    08:15 PM
    Hello,
    What I have is a title block with various visibility settings embedded for various detail items on in the family.
    Among them, is a north arrow detail item, that I've applied a visibility and rotation values to. The visibility one is an instance parameter that, when on the sheet, and the family is selected, you can turn on/off the arrow visibility (plans, to elevations, etc.).
    I have a master sheet index that I've assembled for organizing Sheet name, Sheet number, drawn/checked by, Guide Grid, etc..
    I'm trying to add (or recreate using shared parameters?) the visibility setting and (if possible) my Arrow rotation parameter so I can have them included/controlled from my Master Sheet index (schedule) as well.
    Is this possible? And if so, how?
    Thank you in advance!
    Orlando, FL, USA
    3,089
    10:15 PM
    Welcome to Revitforum.
    No, not possible. The schedule of sheets is reading information from sheets, not from titleblocks. Sheets and titleblocks are two different things, not connected. Also, shared parameters can be applied to multiple categories, but "titleblocks" is not a category.
    cganiere likes this.
    February 23, 2015
    2
    08:15 PM
    That makes sense- Thank you
  1. worksets - visibility settings
    By philsogood in forum Architecture and General Revit Questions
    Last Post: May 31st, 2018, 04:51 AM
  2. visibility settings
    By ragip in forum Architecture and General Revit Questions
    Last Post: July 13th, 2013, 02:57 PM
  3. Modelling efficiency and visibility settings
    By KWilkinson in forum Architecture and General Revit Questions
    Last Post: December 19th, 2012, 05:42 PM
  4. Family Visibility Settings
    Last Post: May 27th, 2012, 06:30 PM
  5. 3D visibility settings
    By Will P. in forum Architecture and General Revit Questions
    Last Post: June 22nd, 2011, 05:38 PM
Tags for this Thread
