Results 1 to 4 of 4
Thread: Cut with void in an array
    November 5, 2018
    3
    10:55 PM
    Hi, attached my model I am currently working on.
    What I want is to cut the curved array elements on the end of the length of this family.
    That doesn't work, because when adding length to this object and there will be more curved elements in the array, they are arrayed later then the void, so it won't cut.
    I searched a lot on the internet, but still I didn't get this working.
    Can anybody help me out?
    Thanks in advance!
    Attached Files Attached Files
    Mr. Revit OpEd
    2,878
    03:55 PM
    Don't have access to 2019 at the moment, this blog post might address the issue though. It describes reversing the logic, array the void instead so the order of creation is not altered.
    November 5, 2018
    3
    10:55 PM
    Hi Steve, thanks for the quick reply.
    I found that post too, but it didn't help me for my project.
    I have made an array now with a void using my total length, but it doesn't cut.
    See attached new file, it's Revit 2019
    Can anyone pls help me out, I am stucked.
    Thanks!
    Orlando, FL, USA
    3,098
    06:55 PM
    Hello,
    This graphic shows a different approach. I hope that helps.
    Notice the parts that I mark with an "X". In my opinion, that is not required. Don't try to cut an extra portion of an element of the array. Instead, make those end parts a half-module that is fixed, not part of the array. That separates length of array from length of beam. Then constrain the array of solids and the array of voids (the small holes) between the reference planes that mark the length of array.
    Attached Thumbnails Attached Thumbnails Cut with void in an array-2018-12-29_8-51-48.jpg
  1. Cut a Nested Family (used to create an array) with a Void
    By ndjabiras in forum Architecture - Family Creation
    Last Post: November 30th, 2017, 03:07 PM
  2. Void to cut end off array of nested family - A metal deck roof sheet problem
    By williamturner1 in forum Architecture and General Revit Questions
    Last Post: October 23rd, 2016, 05:20 PM
  3. Parametric Void Array Window
    By krcbickel in forum Architecture - Family Creation
    Last Post: June 12th, 2014, 02:13 PM
  4. Void form not creating void.
    By mikey1073 in forum Architecture - Family Creation
    Last Post: December 6th, 2012, 02:13 PM
  5. Revit OpEd: Array the Void Instead
    Last Post: August 23rd, 2011, 03:07 PM
