Results 1 to 2 of 2
Thread: Fill a dubble curved mass face with panels
    November 5, 2018
    3
    04:28 PM
    Hi all,
    I am quit new to Revit. I have made a test of a double curved mass, approximaltely 13x8 meters, with curves of low and higher radius.
    I want to place pattern based panels on the mass, but thes panels have some restrictions: they can only bend at a radius on a straight line (so they are not curved as panels)
    My question is: What pattern fits well in this situation? To fill this mass with bended panels (faceted) but no curved panels?
    I was trying to make it with hexagons and made a custom patterned panel, but I don't exactly know how to make the parameters for this.
    See the image attached. The red lines are milled lines to bend the panel up- or downwards, the dashed lines are suggestions of me for additional bend lines?
    Because there is no material of the hexagon been removed from the panel, the sides can bend, depending of the other part isn't bended. So I want to make this hexagon smarter with parameters, but can's figure out well how to do so?
    Maybe there are suggestions of doing the curtain panel fill on my mass object in a totally other way?
    I really want to hear that...
    Thanks in advance!!
    Attached Thumbnails Attached Thumbnails Fill a dubble curved mass face with panels-hexagon-panel.jpg
    Orlando, FL, USA
    3,089
    12:28 PM
    Hello, Mikeymore, welcome to Revitforum.
    I would like to help you on this, but the question is not clear enough. Can you post a sketch that gives an idea of the desired result?
  1. how to model this ? walls by face ? adaptive panels ? how to add a structure to it ?
    By kunster in forum Architecture and General Revit Questions
    Last Post: February 12th, 2015, 12:31 AM
  2. Help, how to adjust fill pattern on a mass?
    By Nielsen in forum Architecture and General Revit Questions
    Last Post: October 10th, 2014, 11:50 PM
  3. In a curved mass how to turn only one edge to straight without affecting the mass ?
    By Diaa.Sabri in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 2nd, 2013, 10:34 PM
  4. Buildz: Repeat and Divide Prt I: curved panels
    By Buildz in forum Blog Feeds
    Last Post: May 7th, 2012, 05:15 AM
  5. Wall by face - curved face bug
    By brenehan in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 2nd, 2012, 12:56 AM
