Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: difference between graphics and visibility
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    137
    08:43 AM
    hello
    one of my colleague is using graphics to make some elements not visible whereas i use to do it with visibility
    what is the difference wetween these 2 parameters and what the limits of each type? why usin one type btter than the other?
    thanks
    Phil
    May 18, 2011
    Calgary, AB
    401
    02:43 AM
    Are you referring to where to group the parameter under when building a family? It's just a way to structure the parameters of a family to keep things organized, so the question I'd be asking is where would I look for this?. I'd use visibility.
    June 30, 2016
    Lyon - France
    137
    08:43 AM
    Hi
    I don't understand what you mean by "a way to structure the parameters of a family"
    In my case, I only want to hide some objects in the family
    Phil
    Envoyé de mon Redmi 3S en utilisant Tapatalk
    May 18, 2011
    Calgary, AB
    401
    02:43 AM
    So what "group" you use, doesn't matter too much. In the image I have a parameter under graphics and I have one under visibility. Is that what you were referring to in the original question?
    If yes, then I'd use visibility.
    Attached Thumbnails Attached Thumbnails difference between graphics and visibility-parameter.jpg
    June 30, 2016
    Lyon - France
    137
    08:43 AM
    thanks Chris, this is what i was asking but what graphocs would be use for if visibility is doing the same job?
    Phil
    July 7, 2011
    Rotterdam, Holland
    1,229
    10:43 AM
    I think I have used graphics when I need to have a detail item in a family (so 2D info) where I need to change it's visibility and I use visibility for 3D objects. But I am not a 100% sure I have done that for all of them. Good idea to check that for consistency.
    But you could indeed use any category for any type of parameter, it is just a way for you (and your company) to group them so people know where to look for them.
    July 21, 2018
    53
    06:43 PM
    Does visibility get buried towards the bottom once you have a few other parameter groups involved? I've always leaned towards graphics for organising the on/off stuff and I think it was mainly just so it was near the top. Especially when they're instance based, it was easier for most people in the office to select the family and then right near the top of properties browser have all their check boxes for turning things on and off. I'm that used to doing it out of habit that I'd forgotten all about the visibility section. Now that you bring it up I'm really not sure what the distinction is supposed to be.
    July 7, 2011
    Rotterdam, Holland
    1,229
    10:43 AM
    I think it does get buried at the bottom, because the groups are alphabetically and the parameter inside the groups you can change the order of. So that is indeed something you might wanna take into account.
    May 18, 2011
    Calgary, AB
    401
    02:43 AM
    V2017.2, groups are not alphabetical.
    #01 is the first group, then I worked down the list. The groupings are all over the map.
    Attached Thumbnails Attached Thumbnails difference between graphics and visibility-family-parameters_1.jpg   difference between graphics and visibility-family-parameters_2.jpg
    June 30, 2016
    Lyon - France
    137
    08:43 AM
    Very interesting
    Thank you so much
    Phil
  1. graphics difference between project and family
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: April 5th, 2018, 02:38 PM
  2. Visibility Graphics Override help
    By JWelsh1990 in forum Architecture and General Revit Questions
    Last Post: December 16th, 2015, 02:08 AM
  3. Visibility Graphics Lock-up?
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: November 30th, 2012, 07:15 PM
  4. Graphics Visibility
    By DGoffron in forum Architecture and General Revit Questions
    Last Post: October 18th, 2012, 09:23 PM
  5. Visibility/Graphics - Workset Visibility Setting
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: July 27th, 2012, 02:49 PM
Tags for this Thread
