Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By duende123
Thread: Parameters and constraints
    February 16, 2016
    102
    06:06 PM
    Is the only way to constrain an element to place a dimension on it and then add a parameter?
    Can you not constrain an element by attaching it to another element so that if the first element moves, the second does also?
    Must parameters be applied in sketch mode, if you try to add them later it is not possible?
    Member duende123's Avatar
    November 20, 2015
    186
    02:06 PM
    No,
    Yes,
    Maybe.
    too philosophical ...
    I think you should be more specific
    What are you trying to do?
    Robin Deurloo likes this.
    July 10, 2015
    Boise, Idaho
    664
    12:06 PM
    Attach parameters to reference lines and/or planes. Attach the effected element to the line and/or plane.
  1. Some more constraints..where?
    By Secttor in forum MEP - General
    Last Post: April 26th, 2014, 08:46 PM
  2. Select constraints
    By jbenoit44 in forum Tutorials, Tips & Tricks
    Last Post: November 4th, 2013, 08:38 PM
  3. constraints
    By nik.sands in forum Architecture and General Revit Questions
    Last Post: May 10th, 2013, 07:28 AM
  4. Line Constraints, WTH?
    By Nivek in forum Architecture - Family Creation
    Last Post: January 26th, 2012, 03:20 PM
  5. Constraints - best methods?
    Last Post: January 7th, 2012, 09:24 AM
