Results 1 to 4 of 4
Thread: Family Wall Sweep Issues
    September 19, 2018
    2
    06:47 PM
    I have a question about the wall sweep command in Revit family. A model of a house was made and the details of the exterior were developed to include two different material conditions: a metal siding and a wood screen element to the entry. Both of these elements were made in Revit family with the wall sweep command. The issue is once they were made and brought into the project, if one of the wall sweep families is edited, ie, the width of the wood is changed, it also changes the width of the metal siding from the other family, despite being made separately. Any idea why this is so? And what could be done differently so as to have independent control over these two elements?
    Any insight is appreciated, thank you.
    Kelsie
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,949
    09:47 PM
    There are several possibilities.
    Uploading the families would help a lot.
    January 19, 2012
    322
    09:47 PM
    A possibility:
    So, Wall Sweeps uses a loaded Profile: make sure to have 2 Type Families (or 2 separate Profile Families) (maybe call them by the material for example) in this Profile Family (make it "parametric" obviously to specify changing depths), then make sure you have 2 Wall Sweep types with their dedicated "Type Family" (or the 2 separate Profile Families).
    Best Option IMHO:
    Create a wall type for each instance, then create a Stack Wall. If few varying heights more stack wall types, but if many variations maybe Wall sweeps for the least common.
    God is in the details....getting lost in them or not seeing enough of them is another thing...
    September 19, 2018
    2
    06:47 PM
    Thank you
    Quote Originally Posted by cftrevizo View Post
    A possibility:
    Best Option IMHO:
    Thank you so much! This set us on the right track.
  1. Nested Family not Cutting Wall Sweep
    Last Post: January 17th, 2017, 03:05 PM
  2. Couple of Family issues: Flexing Sweep Angle and Sizing in Project.
    By BarryMClark in forum MEP - Family Creation
    Last Post: July 22nd, 2016, 10:18 PM
  3. Is there an advantage to using a wall sweep as opposed to an in-place family sweep?
    By cnd in forum Architecture and General Revit Questions
    Last Post: September 14th, 2015, 08:16 PM
  4. Unsolved-Wall Sweep Issues
    By David Wilkinson in forum Architecture and General Revit Questions
    Last Post: July 26th, 2014, 01:25 PM
  5. Family won't cut wall sweep
    By dzatto in forum Architecture - Family Creation
    Last Post: January 20th, 2011, 09:07 PM
