Results 1 to 2 of 2
Thread: Splitting elements
    February 16, 2016
    102
    02:18 PM
    Splitting elements
    Hello I am trying to adjust the dimensions of a tubular piece of metal, part of a piece of furniture, created with the sweep tool.
    It is not attached to any reference planes and hence not truly parametric.
    So I thought I would use split tool but this only seems to work for walls not a circular element extruded with the sweep tool. Why is that?
    Orlando, FL, USA
    3,089
    10:18 AM
    You need to select the sweep solid and edit the path. The split tool can break walls or lines (a path). But the path of a sweep must be continuous, though. Otherwise you get an error saying "More than one loop not allowed".
  1. Splitting up a model
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: October 8th, 2018, 02:41 AM
  2. Splitting a beam
    By zaid86 in forum Structure - General Questions
    Last Post: March 29th, 2012, 07:16 PM
  3. Splitting tool
    By lucis29 in forum Structure - General Questions
    Last Post: October 18th, 2011, 09:11 AM
  4. Revit schedule splitting
    By maskelllee in forum Architecture and General Revit Questions
    Last Post: July 21st, 2011, 07:17 PM
