Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By Robin Deurloo
  • 2 Post By Steve_Stafford
Thread: Naming Grid Lines
    March 11, 2015
    3
    02:05 PM
    Naming Grid Lines
    Hello! Real basic - how do I add a parameter to my Grid family (Grid Head Family) to display an additional line for naming the grid line? See the attached image for clarification. I feel like this should be an easy fix but I can't quite find the right solution that isn't 'live text' in the plans.
    Gold Coast
    2,602
    12:05 AM
    If you want a new type for each individual grid you should be able to put a label in your grid head family.
    March 11, 2015
    3
    02:05 PM
    ..Tried that unfortunately. There are not parameters available for naming the grid. Only the value of the bubble itself. I'm working on trying to get a shared parameter to work but am not having much success..
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:05 PM
    Seems to work fine with a shared parameter in your grid head family AND the same one in your project as a Project Parameter as Instance of course.
    You just end up with a question mark if you do not name the grid, but that can be fixed with making a second grid type with a different grid head I guess.
    cganiere likes this.
    March 11, 2015
    3
    02:05 PM
    That's it! Thank you! I knew it had an easy fix. Got both horizontal and vertical tags working with fresh text!
    but now I've en courted another problem - the text placement on the horizontal bands are all goofy. I can't quite seem to find the logic on why Revit is moving my tag...help!
    Mr. Revit OpEd
    2,861
    07:05 AM
    The short answer, it is unlikely you'll get a desired result for every possible orientation of the grid. For example, at a different scale or when the grids are at angles. You might find a happy medium so it works for this project but you'll end up revisiting it again on the next.
    It would be easier (more consistent/reliable) to use a different grid circle/shape (or double line, dashes) to identify a specific purpose or grid type.
    GMcDowellJr and cganiere like this.
  1. Revit Grid Lines With Grid # in Linetype
    By RenChan in forum Tutorials, Tips & Tricks
    Last Post: May 1st, 2017, 08:20 PM
  2. Grid lines.
    By wwdreamb in forum Architecture and General Revit Questions
    Last Post: January 25th, 2017, 02:45 PM
  3. Vigilante Grid Lines
    By mdomer in forum Architecture and General Revit Questions
    Last Post: April 4th, 2016, 06:42 PM
  4. where are my grid lines????
    By konetarchitecture in forum Architecture and General Revit Questions
    Last Post: July 18th, 2014, 12:38 PM
  5. Break grid lines possible?
    By Andres Franco in forum Architecture and General Revit Questions
    Last Post: October 20th, 2013, 01:41 AM
Tags for this Thread
