Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree6Likes
Thread: travel distance line
    March 14, 2016
    34
    10:05 AM
    I am looking for a solution that can create a travel distance lenght that you can tag and gave a distance. Current I use spline for detail line and type in distance. I have look at other option create model family line but that only gave 2 point and gave distance from 2 point doesn't gave total length many segments line. I want to to do like spline and tag and gave total distance. Please share if you have better option doing travel distance.
    Thanks,
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:05 PM
    I hear people use railings for that. Never did travel distance lines in Revit before, but that will work (you can tag the length of the railing).
    Use filters to show or hide them in the views you want.
    GMcDowellJr and cganiere like this.
    December 21, 2010
    Phoenix, AZ
    2,556
    07:05 AM
    I agree with Robin, railings are the way to go.
    You can make a multi-point adaptive competent but the workflow sucks and you still need to filter them out of views.
    July 10, 2015
    Boise, Idaho
    641
    08:05 AM
    A railing... I should have asked you guys how to make one of these lines a few months ago. I made a line based family that added arrows the longer it got and also showed the length on the plan. It looked cool, worked bad and nobody likes it. It's always too busy and cluttered.
    December 21, 2010
    Phoenix, AZ
    2,556
    07:05 AM
    My last office had a need for travel lines that showed not distance, but aggregate occupancy to show how we assumed people would exit the space. I didn't find it a helpful tool but "that's the way they'd always done things." In that case, a line-based family, with nested annotations, worked well.
    March 14, 2016
    34
    10:05 AM
    Thanks guys, line based family doesn't gave total length. I will try railing. Also, I like to have more like spline instead straight line that gave me better control of the length.
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    787
    09:05 AM
    Quote Originally Posted by Hoangtin View Post
    I will try railing.
    This can help.
    kamranmirza likes this.
    January 19, 2012
    322
    09:05 AM
    I customized the attached for a Religious Center Campus I just did to the PM's preference. Use & Customize as yawl see fit.
    Attached Files Attached Files
    cganiere and kamranmirza like this.
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:05 PM
    And of course after I posted this about travel lines I had to use them as well and I must say it works well !
    10,036
    09:05 AM
    All railings here, since 2015.
  1. Alive in the Lab: RS Components: The Future of Space Travel
    By Alive in the Lab in forum Blog Feeds
    Last Post: May 23rd, 2018, 11:15 AM
  2. Work and Travel around the world with Revit
    By Thommynat0r in forum Out There
    Last Post: August 2nd, 2016, 01:21 PM
  3. Polyline in Revit to measure travel distances?
    By gentlepuppies in forum Architecture and General Revit Questions
    Last Post: December 10th, 2015, 02:15 PM
  4. Travel help/ideas
    By MPwuzhere in forum Out There
    Last Post: June 5th, 2014, 12:10 PM
  5. Revit Kid: #ACSA - Boston - Day 1 - Travel
    By The Revit Kid in forum Blog Feeds
    Last Post: March 1st, 2012, 04:45 PM
Tags for this Thread
