Results 1 to 2 of 2
Thread: Reference planes and work plane
    February 16, 2016
    102
    02:36 AM
    Hello I am trying to create a heat pump.
    In front elevation I have created a reference plane called “Top of Base”.
    This I did by clicking two points 25mm above default reference plane used for plans.
    However, I try to look at reference plane by using workplane > show.
    I would have thought plane created in front elevation would be hovering over plane used for plan.
    But no, it is at 90 degrees to this.
    Is this what I should have expected? i.e. when you create a reference plane you are creating the Z plane, the XY plane is perpendicular to this?
    See attached images.
    Attached Thumbnails Attached Thumbnails Reference planes and work plane-heat-pump-21-09-18.jpg   Reference planes and work plane-heat-pump-21-09-18a.jpg
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:36 AM
    When you were in the elevation and choose Workplane > Show it would indeed show the Workplane you are currently in and not the one you just created.
    If you want to show a different Workplane you have to Set the Workplane as current first with the Workplane > Set function, pick the Top of Base ref plane as your Workplane and it should show the right one when you do Workplane > Show.
  1. Replies: 0
    Last Post: September 4th, 2018, 10:15 AM
  2. Wishlist - Right-click on named reference plane, set as work plane.
    By ryntau in forum Architecture - Family Creation
    Last Post: September 22nd, 2015, 04:30 PM
  3. General noob question: Work planes perpendicular to xy plane
    By ronario81 in forum Architecture and General Revit Questions
    Last Post: October 8th, 2013, 05:01 AM
  4. How to change reference line as the work plane in the middle of blend
    By felix_hadi in forum Tutorials, Tips & Tricks
    Last Post: March 14th, 2012, 08:33 AM
  5. How to work appropriately with Reference Planes and Reference Lines???
    By SkepticSon in forum Architecture and General Revit Questions
    Last Post: June 26th, 2011, 02:06 AM
