Results 1 to 3 of 3
Thread: triming a sweeped surface in general model family template
    September 19, 2018
    1
    07:35 PM
    Question triming a sweeped surface in general model family template
    Hello,
    I am trying to make a corner of 2 different surfaces that are made by sweep command merge smoothly. I wonder If I can able to trim a surface that has made by sweep command so that I will make a group of 2 surfaces.
    One of the surfaces is like corrugated metal panel, and the other one is flat surface they combine with each other a 103° angle and flat surface cap the other one.
    I tried to make void, so I can trim the corner but then I couldn't make the other one visible because of the void.
    Is there a way to make sweep command with two different profile (one starts at the beggining and the other one starts at the corner) so that corner can be merged.
    Thanks.
    April 24, 2018
    31
    11:05 AM
    Can you attach a copy of the family?
    Senior Member
    August 19, 2011
    New Hampshire
    503
    12:05 PM
    Move the void(s) vertically until it(they) isn't(aren't) cutting either sweep. Control the cut/uncut properties of the void(s) using the proper commands. Move the void(s) back into position so they are cutting the sweep(s).
  1. Schematic template vs. general purpose template + workflow (long winded post, sorry)
    By kpcarch in forum Architecture and General Revit Questions
    Last Post: September 10th, 2013, 07:27 AM
  2. Triming a curved wall to the underside of a stair
    By Pashcal in forum Architecture and General Revit Questions
    Last Post: June 28th, 2012, 03:15 PM
  3. general notes template or family
    By kev4174 in forum Structure - Family Creation
    Last Post: February 27th, 2012, 03:16 PM
  4. General Question: Family vs. build in the model
    Last Post: December 23rd, 2010, 02:37 PM
