Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By elton williams
Thread: OOTB LVL-Laminated Veneer Lumber-Section DETAIL ITEM fill region rotation (2017)
    June 26, 2014
    85
    03:34 AM
    i am trying to use the Out Of The Box LVL-Laminated Veneer Lumber-Section DETAIL ITEM. when i place this detail item in my model and rotate it the fill region stays in the same direction as it was in its original position. how can i correct this so that the fill region is relative to the detail item? i am attaching a screen shot of what i described.
    Attached Thumbnails Attached Thumbnails OOTB LVL-Laminated Veneer Lumber-Section DETAIL ITEM fill region rotation (2017)-lvl-rotate.png
    Gold Coast
    2,466
    08:34 PM
    Quote Originally Posted by ledgewood33 View Post
    Change the pattern to a model pattern
    cganiere likes this.
    June 26, 2014
    85
    03:34 AM
    thank you, i will give that a try. you would think autodesk would get it right the first time??
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    832
    09:34 PM
    There a few families in the box with graphic issues. A fridge which has an annotation REF in plan, that also shows in site plan. And no visibility parameter associated to it. I've learnt a lot, (well not much compared to some of you astronauts!), about families by having to fix them as they come from suppliers. I have a couple i take students through to get it into their heads that families might not be perfect, and software certainly aint.
  1. Ootb Revit detail component stretch controls
    By Zuefeldt Design in forum Architecture - Family Creation
    Last Post: August 29th, 2018, 01:13 AM
  2. Rotate drafting pattern within detail item 2017
    By ledgewood33 in forum Architecture - Family Creation
    Last Post: November 1st, 2017, 02:15 PM
  3. Why filled Region (in detail item) Disappear?
    By RaffaBunggee in forum Architecture - Family Creation
    Last Post: June 13th, 2017, 07:44 PM
  4. Detail item list not show full list (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: November 18th, 2016, 03:41 PM
  5. Crop Region rotation?
    Last Post: March 6th, 2012, 09:28 PM
