Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By Robin Deurloo
  • 1 Post By Rulf21
Thread: Family parameter problem
    February 7, 2018
    2
    06:56 PM
    Question Family parameter problem
    Hi!
    I have a problem...
    I want to do a family that have a line going from on corner to an other in a rectangel. In middle of this line I want a parameter text that stays 90 degrees against this line. And also the text should be in the middle all the time. you should be able to change the size of the rectangel. see picture
    Thanks for help!
    /Rulf
    Attached Thumbnails Attached Thumbnails Family parameter problem-example.png
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:56 PM
    I was going to explain what I did with my family, but that would have been a long bit of text and I'm sure not very clear. So instead I decided to add it to the post. I was asked by a client to make this and it is a bit more complicated than what you are looking for, because they wanted the text to be on the line and not above it, but the idea is similar.
    Basically it is a few nested generic annotations and formula's for the angles
    Attached Files Attached Files
    Andres Franco likes this.
    February 7, 2018
    2
    06:56 PM
    Quote Originally Posted by Robin Deurloo View Post
    Thanks Solved my problem
    Robin Deurloo likes this.
  1. Replies: 0
    Last Post: January 11th, 2018, 01:45 AM
  2. Replies: 0
    Last Post: January 10th, 2018, 07:15 AM
  3. Replies: 0
    Last Post: February 24th, 2016, 03:15 AM
  4. Replies: 0
    Last Post: February 21st, 2016, 10:15 PM
  5. select by parameter? curtain wall panels' materials by parameter, by type or family?
    By oompa_l in forum Architecture and General Revit Questions
    Last Post: January 24th, 2013, 03:20 PM
