Results 1 to 6 of 6
Thread: Column base breaks when level or offset is changed
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    446
    04:33 AM
    I've never had so much trouble making a family. I made a revolve profile around the bottom of a structural column family for a cast iron column base piece. But when I change the bottom level of the column, it breaks. Change the offset, breaks. Even try to place the column on a different level to start with using a plan view for another level. Breaks.
    The top piece seems to be working fine. How the heck can I make this base piece work??
    Attached Files Attached Files
    Coeur d Alene, ID
    4,736
    02:33 AM
    Try creating a separate profile vs a sketch profile within the family....less to constrain. The top works because it isn't constrained to anything.
    July 14, 2016
    83
    09:33 AM
    I don't have compatible version of Revit to open the file, but it sounds like you might have 2 reference lines / planes overlapping, and the base of the column is locked to the wrong one. Happens all the time, detach and attach again, to the correct one.
    July 7, 2017
    Hernando, MS
    446
    04:33 AM
    Quote Originally Posted by paidpal View Post
    No, it only has a single ref plane at the bottom, aligned and locked to the lower ref level, just like in the stock column template.
    July 7, 2017
    Hernando, MS
    446
    04:33 AM
    Does that work for a revolve, or only a sweep? I've never understood the best cases to use revolve vs. sweep. It seem like a sweep can do the same thing a revolve can + more.
    Senior Member
    August 19, 2011
    New Hampshire
    503
    05:33 AM
    Changing the bottom decorative element to a sweep fixes the problem on my end.
  1. Wall base offset issue with foundation attachment. Any advice?
    By jmthomas in forum Structure - General Questions
    Last Post: August 5th, 2016, 06:17 PM
  2. Offset values of Ducts were changed after draw
    By hkc1991 in forum MEP - General
    Last Post: June 15th, 2016, 05:32 AM
  3. Pipe/Duct Tags Move when Offset is Changed?
    By evan.dodds in forum MEP - General
    Last Post: January 22nd, 2016, 01:31 AM
  4. Revit Extensions placing column base connection at top of column
    By wardley31 in forum Architecture and General Revit Questions
    Last Post: December 4th, 2014, 10:29 AM
  5. Curtain Wall with base offset of 2' - help please.
    By digitalputty in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2012, 08:42 PM
