Results 1 to 2 of 2
Thread: Nested Family...Visibility parameters
    February 18, 2014
    10
    06:02 PM
    Question Nested Family...Visibility parameters
    Hello,
    I have a nested family with several sub families loaded in it.
    Each sub family has 2 geometry one square and another shape different for each. Say square and triangle then square and circle, etc.
    What i want to do is use a parameter "Show Detailed Display" in the project to turn on the none square geometry and hide the squares in each nested sub family.
    This way i can switch between the shapes as i need to.
    The shapes represent different levels of detail for imported models from SolidWorks. They are very detailed and heavy imports. using a simplified geometry set for speed and the detailed import for final drawing views and rendering.
    Hope all this makes sense.
    Any help on achieving this would be nice. Thank you.
    Stonehands99
    Senior Member
    August 19, 2011
    New Hampshire
    503
    10:02 PM
    Sounds like you'll want to make use of types and a Family Type parameter.
  1. Replies: 0
    Last Post: March 16th, 2017, 03:15 AM
  2. Visibility Issue with Nested Generic Model in Door Family
    By billiam in forum Architecture - Family Creation
    Last Post: May 23rd, 2016, 08:48 PM
  3. Replies: 3
    Last Post: December 30th, 2015, 06:08 PM
  4. Plan visibility of nested family with shared components.
    By jmk in forum Architecture - Family Creation
    Last Post: October 1st, 2014, 05:20 PM
  5. Visibility parameter and nested family: bug?
    By jbenoit44 in forum Structure - Family Creation
    Last Post: August 30th, 2011, 03:23 PM
